Webdav connexion issue
Hi
I’m trying to use the WebDav interface.
Our login/passwords are checked through a LDAP server. The login name is not our email address.
I tried the following using the curl command line :
  • User/Password ==> Principal with name xxx not found
  • Email/Password ==> password login forbidden
  • Emaill/AppPassword ==> No public access to this resource., Username or password was incorrect, No ‘Authorization: Bearer’ header found. Either the client didn’t send one, or the server is mis-configured, Username or password was incorrect
Of course I double checked the login & password used.
What shall I try ?
Ok, got it. The URL mentioned in Basic APIs — Nextcloud latest Developer Manual latest documentation shall be replaced by the one you find in “Files setting” and then the App Passwords works correctly…
