example
longer
example
here
Nextcloud version (eg, 20.0.5): 24.0.7
Operating system and version (eg, Ubuntu 20.04): TrueNAS 13.0U2
Apache or nginx version (eg, Apache 2.4.25): Caddy 2.5.2
PHP version (eg, 7.4): PHP 8.0
Can’t update through the web interface or command line. It seem to think all the steps to update are already done. All the steps to update have a green check before I do anything. Update button goes to immediately to the main page. The log files have could not verify token errors. I am able to login to NC as admin without issue that I know of.
- Try to update NC version with the update button
- or Issue OCC command to update NC
PASTE HERE
'passwordsalt' => 'redacted',
'secret' => 'redacted',
0 => 'localhost',
1 => 'cloud.mydomain.com',
2 => '192.168.5.81',
'datadirectory' => '/mnt/files',
'version' => '24.0.7.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/mysql.sock',
'dbuser' => 'nextcloud',
'dbpassword' => 'redacted',
'instanceid' => 'redacted',
'logtimezone' => 'America/New_York',
'log_type' => 'file',
'logfile' => '/var/log/nextcloud.log',
'loglevel' => '2',
'logrotate_size' => '104847600',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'redacted',
'mail_domain' => 'gmail.com',
'mail_smtpauth' => '1',
'mail_smtpport' => '465',
'mail_smtpname' => 'redacted',
'mail_smtppassword' => 'redacted',
'mail_smtphost' => 'smtp.gmail.com',
'overwritehost' => 'cloud.mydomain.com',
'default_phone_region' => 'US',
'overwrite.cli.url' => 'https://cloud.mydomain.com',
'theme' => '',
'data-fingerprint' => 'redacted',
'trusted_proxies' =>
0 => '192.168.5.81',
1 => 'localhost',
2 => 'cloud.mydomain.com',
3 => '::1',
'updater.secret' => 'redacted',
PASTE HERE
PASTE HERE
Error core Tried to log in admin but could not verify token
