example
longer
example
here
Nextcloud version (eg, 12.0.2): 18.0.0.10
Operating system and version (eg, Ubuntu 17.04): openSUSE Tumbleweed
Apache or nginx version (eg, Apache 2.4.25): nginx/1.17.7
PHP version (eg, 7.1): 7.4.2
The issue you are facing: After upgrading PHP from 7.3.7 to 7.4.2 Nextcloud 17.0.1.1 refused to work. Then after upgrading Nextcloud to 18.0.0.10 Windows client is working fine, but the web login does not work, it loops to itself. To be more precise, it loops to the page: https://nextcloud.mydomain.tld/login?redirect_url=/apps/files/
I tried the browsers: Chrome, Opera, Firefox, Pale Moon. Internet Explorer behaves different, it suggests to save files/
and does not go further.
there is nothing in the log file concerning this issue after the upgrade
{"reqId":"MxNzQDTVVm64hRi7fzLG","level":1,"time":"2020-02-09T12:35:51+03:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::startCheckCodeIntegrity: Starting code integrity check...","userAgent":"--","version":"17.0.1.1"}
{"reqId":"MxNzQDTVVm64hRi7fzLG","level":1,"time":"2020-02-09T12:35:55+03:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::finishedCheckCodeIntegrity: Finished code integrity check","userAgent":"--","version":"17.0.1.1"}
{"reqId":"MxNzQDTVVm64hRi7fzLG","level":1,"time":"2020-02-09T12:35:55+03:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::updateEnd: Update successful","userAgent":"--","version":"18.0.0.10"}
{"reqId":"MxNzQDTVVm64hRi7fzLG","level":1,"time":"2020-02-09T12:35:55+03:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::maintenanceActive:Maintenance mode is kept active","userAgent":"--","version":"18.0.0.10"}
{"reqId":"MxNzQDTVVm64hRi7fzLG","level":1,"time":"2020-02-09T12:35:55+03:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::resetLogLevel: Reset log level to Warning(2)","userAgent":"--","version":"18.0.0.10"}
{"reqId":"OEWVCWIc31MLvlszXXBb","level":3,"time":"2020-02-09T12:40:13+03:00","remoteAddr":"192.168.2.3","user":"--","app":"PHP","method":"GET","url":"/apps/theming/styles?v=0","message":"Trying to access array offset on value of type null at /srv/www/nextcloud/nextcloud/3rdparty/leafo/scssphp/src/Compiler.php#5230","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36 OPR/66.0.3515.72","version":"18.0.0.10"}
{"reqId":"nEm08swLzDd3NI2UUt94","level":3,"time":"2020-02-09T13:43:48+03:00","remoteAddr":"192.168.2.3","user":"--","app":"PHP","method":"GET","url":"/apps/theming/styles?v=0","message":"Trying to access array offset on value of type null at /srv/www/nextcloud/nextcloud/3rdparty/leafo/scssphp/src/Compiler.php#5230","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36 OPR/66.0.3515.72","version":"18.0.0.10"}
# sudo -u nginx php occ config:list
"***REMOVED SENSITIVE VALUE***"
"dbtype": "mysql",
"version": "18.0.0.10",
"overwrite.cli.url": "https:\/\/***REMOVED SENSITIVE VALUE***",
"dbport": "",
"mysql.utf8mb4": true,
"htaccess.RewriteBase": "\/",
"overwriteprotocol": "https",
"logfile": "\/var\/log\/nextcloud\/nextcloud.log",
"syslog_tag": "nextcloud",
"loglevel": 2,
"logtimezone": "Europe\/Moscow",
"knowledgebaseenabled": true,
"filelocking.enabled": "true",
"redis": {
"port": 0,
"timeout": 0
"theme": "",
"mail_smtpmode": "sendmail",
"mail_smtpauthtype": "PLAIN",
"mail_smtpport": "25",
"mail_sendmailmode": "smtp"
"apps": {
"accessibility": {
"enabled": "yes",
"installed_version": "1.4.0",
"types": ""
"activity": {
"enabled": "yes",
"installed_version": "2.11.0",
"types": "filesystem"
"backgroundjob": {
"lastjob": "19309"
"cloud_federation_api": {
"enabled": "yes",
"installed_version": "1.1.0",
"comments": {
"enabled": "yes",
"installed_version": "1.8.0",
"types": "logging"
"core": {
"backgroundjobs_mode": "cron",
"enterpriseLogoChecked": "yes",
"installedat": "1539350777.1317",
"lastcron": "1581248103",
"lastupdateResult": "{\"version\":\"17.0.3.1\",\"versionstring\":\"Nextcloud 17.0.3\",\"url\":\"https:\\\/\\\/download.nextcloud.com\\\/server\\\/releases\\\/nextcloud-17.0.3.zip\",\"web\":\"https:\\\/\\\/docs.nextcloud.com\\\/server\\\/17\\\/admin_manual\\\/maintenance\\\/upgrade.html\",\"changes\":\"https:\\\/\\\/updates.nextcloud.com\\\/changelog_server\\\/?version=17.0.3\",\"autoupdater\":\"1\",\"eol\":\"0\"}",
"lastupdatedat": "0",
"oc.integritycheck.checker": "[]",
"public_files": "files_sharing\/public.php",
"public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
"scss.variables": "db81cddf52fdb3c8ca1e4c859e214124",
"theming.variables": "b92d206521717ac032f8aa58d3c7ff2f",
"vendor": "nextcloud"
"dav": {
"buildCalendarReminderIndex": "yes",
"buildCalendarSearchIndex": "yes",
"chunks_migrated": "1",
"enabled": "yes",
"installed_version": "1.14.0",
"regeneratedBirthdayCalendarsForYearFix": "yes",
"federatedfilesharing": {
"enabled": "yes",
"types": ""
"federation": {
"enabled": "yes",
"types": "authentication"
"files": {
"cronjob_scan_files": "500",
"enabled": "yes",
"installed_version": "1.13.1",
"files_pdfviewer": {
"enabled": "yes",
"installed_version": "1.7.0",
"types": ""
"files_rightclick": {
"enabled": "yes",
"installed_version": "0.15.2",
"types": ""
"files_sharing": {
"enabled": "yes",
"installed_version": "1.10.1",
"files_texteditor": {
"enabled": "no",
"installed_version": "2.8.0",
"types": ""
"files_trashbin": {
"enabled": "yes",
"types": "filesystem,dav"
"files_versions": {
"enabled": "yes",
"installed_version": "1.11.0",
"files_videoplayer": {
"enabled": "yes",
"types": ""
"firstrunwizard": {
"enabled": "yes",
"installed_version": "2.7.0",
"types": "logging"
"gallery": {
"enabled": "no",
"installed_version": "18.4.0",
"types": ""
"logreader": {
"enabled": "yes",
"installed_version": "2.3.0",
"types": ""
"lookup_server_connector": {
"enabled": "yes",
"installed_version": "1.6.0",
"nextcloud_announcements": {
"enabled": "yes",
"pub_date": "Thu, 24 Oct 2019 00:00:00 +0200",
"types": "logging"
"notifications": {
"enabled": "yes",
"installed_version": "2.6.0",
"types": "logging"
"oauth2": {
"enabled": "yes",
"password_policy": {
"enabled": "yes",
"types": ""
"photos": {
"enabled": "yes",
"installed_version": "1.0.0",
"types": ""
"privacy": {
"enabled": "yes",
"installed_version": "1.2.0",
"types": ""
"provisioning_api": {
"enabled": "yes",
"types": "prevent_group_restriction"
"recommendations": {
"enabled": "yes",
"installed_version": "0.6.0",
"types": ""
"serverinfo": {
"enabled": "yes",
"types": ""
"settings": {
"enabled": "yes",
"types": ""
"sharebymail": {
"enabled": "yes",
"support": {
"enabled": "yes",
"types": "session"
"survey_client": {
"enabled": "yes",
"last_report": "{\"id\":\"ocmij779d6tn\",\"items\":[[\"server\",\"version\",\"15.0.2.0\"],[\"server\",\"code\",\"other\"],[\"server\",\"enable_avatars\",\"yes\"],[\"server\",\"enable_previews\",\"yes\"],[\"server\",\"memcache.local\",\"\\\\OC\\\\Memcache\\\\APCu\"],[\"server\",\"memcache.distributed\",\"none\"],[\"server\",\"asset-pipeline.enabled\",\"no\"],[\"server\",\"filelocking.enabled\",\"yes\"],[\"server\",\"memcache.locking\",\"\\\\OC\\\\Memcache\\\\Redis\"],[\"server\",\"debug\",\"no\"],[\"server\",\"cron\",\"cron\"],[\"php\",\"version\",\"7.3.0\"],[\"php\",\"memory_limit\",536870912],[\"php\",\"max_execution_time\",3600],[\"php\",\"upload_max_filesize\",10737418240],[\"database\",\"type\",\"mysql\"],[\"database\",\"version\",\"10.2.19\"],[\"database\",\"size\",3604480],[\"apps\",\"accessibility\",\"1.1.0\"],[\"apps\",\"activity\",\"2.8.2\"],[\"apps\",\"cloud_federation_api\",\"0.1.0\"],[\"apps\",\"comments\",\"1.5.0\"],[\"apps\",\"dav\",\"1.8.1\"],[\"apps\",\"federatedfilesharing\",\"1.5.0\"],[\"apps\",\"federation\",\"1.5.0\"],[\"apps\",\"files\",\"1.10.0\"],[\"apps\",\"files_pdfviewer\",\"1.4.0\"],[\"apps\",\"files_sharing\",\"1.7.0\"],[\"apps\",\"files_texteditor\",\"2.7.0\"],[\"apps\",\"files_trashbin\",\"1.5.0\"],[\"apps\",\"files_versions\",\"1.8.0\"],[\"apps\",\"files_videoplayer\",\"1.4.0\"],[\"apps\",\"firstrunwizard\",\"2.4.0\"],[\"apps\",\"gallery\",\"18.2.0\"],[\"apps\",\"logreader\",\"2.0.0\"],[\"apps\",\"lookup_server_connector\",\"1.3.0\"],[\"apps\",\"nextcloud_announcements\",\"1.4.0\"],[\"apps\",\"notifications\",\"2.3.0\"],[\"apps\",\"oauth2\",\"1.3.0\"],[\"apps\",\"password_policy\",\"1.5.0\"],[\"apps\",\"provisioning_api\",\"1.5.0\"],[\"apps\",\"serverinfo\",\"1.5.0\"],[\"apps\",\"sharebymail\",\"1.5.0\"],[\"apps\",\"support\",\"1.0.0\"],[\"apps\",\"survey_client\",\"1.3.0\"],[\"apps\",\"systemtags\",\"1.5.0\"],[\"apps\",\"theming\",\"1.6.0\"],[\"apps\",\"twofactor_backupcodes\",\"1.4.1\"],[\"apps\",\"updatenotification\",\"1.5.0\"],[\"apps\",\"workflowengine\",\"1.5.0\"],[\"stats\",\"num_files\",4078],[\"stats\",\"num_users\",2],[\"stats\",\"num_storages\",5],[\"stats\",\"num_storages_local\",2],[\"stats\",\"num_storages_home\",3],[\"stats\",\"num_storages_other\",0],[\"stats\",\"num_comments\",0],[\"stats\",\"num_comment_markers\",0],[\"stats\",\"num_systemtags\",0],[\"stats\",\"num_systemtags_mappings\",0],[\"files_sharing\",\"num_shares\",0],[\"files_sharing\",\"num_shares_user\",0],[\"files_sharing\",\"num_shares_groups\",0],[\"files_sharing\",\"num_shares_link\",0],[\"files_sharing\",\"num_shares_link_no_password\",0],[\"files_sharing\",\"num_fed_shares_sent\",0],[\"files_sharing\",\"num_fed_shares_received\",0],[\"encryption\",\"enabled\",\"no\"],[\"encryption\",\"default_module\",\"no\"]]}",
"last_sent": "1548425391",
"types": ""
"systemtags": {
"enabled": "yes",
"types": "logging"
"text": {
"enabled": "yes",
"installed_version": "2.0.0",
"types": "dav"
"theming": {
"enabled": "yes",
"installed_version": "1.9.0",
"types": "logging"
"twofactor_backupcodes": {
"enabled": "yes",
"types": ""
"updatenotification": {
"core": "17.0.3.1",
"enabled": "yes",
"files_rightclick": "0.15.1",
"types": "",
"update_check_errors": "0"
"viewer": {
"enabled": "yes",
"types": ""
"workflowengine": {
"enabled": "yes",
: there is nothing in the log concerning this issue
PASTE HERE
