I try to install Nextcloud.
I copy the setup-nextcloud.php to the web hoster (1&1 IONOS) and pointed my browser to the file.
I got:
Parse error : syntax error, unexpected ‘version’ (T_STRING) in /homepages/xx/yyyy/htdocs/cld/setup-nextcloud.php on line 394
I changed the setup-nextcloud.php (the […] is my change for a short output only in this posting):
$ diff -us setup-nextcloud.php.orig setup-nextcloud.php.new --- setup-nextcloud.php.orig 2019-04-14 17:06:43.409084297 +0200 +++ setup-nextcloud.php.new 2019-04-14 17:15:11.253751510 +0200 @@ -391,7 +391,7 @@ <div id="login" class="wrapper"> <div class="v-align"> <header><div id="header"> -<?xml version="1.0" encoding="UTF-8" standalone="no"?> +<?php echo '<?xml version="1.0" encoding="UTF-8" standalone="no"?>'; ?> <svg xmlns="http://www.w3.org/2000/svg" version="1.1" [...] /></svg> </div></header><br /> $
If I pointed to the new version I can click on “Next” and the only result is that a “?step=1” is appended to setup-nextcloud.php but nothing else happened.
In former day this kind of installation works on this website - with an old version of owncloud (I have found no new web installer on their website).
TIA Klaus
