Web base updater
HELLO I’m on a share host apache 2.4 php 7.2.7 mysql 5.5.55-0, I run nextcloud 13.0.2
In order to update to 13.0.5, I cliked on “open update system”
I’m asked the secret that I get from the config.php file. Nexcloud get me back to admin page. It looks like nothing happens.
However after 3 or 4 tryes, just before I quit updating, I get the update page while wlicking again on “open update system”.
Since I could not update several time before, could you tell me what’s wrong with my procedure and what I should do.
Now it updated from 13.0.2 to 13.0.4 and I can’t update to 13.0.5. When entering the secret code and press login, I get back to admin page and wait during minutes without getting anywere.
Thanks
You can find a correction here : Cannot update : To login you need to provide the unhashed value of "updater.secret" in your config file
You enter the hash string of characters in your config.php and enter the plain text key in the login when you ask for updating.
However, I got to open a new windows of nexcloud to get update started.
Good luck to everybody.
