example
longer
example
here
Nextcloud version (eg, 20.0.5): 21.0.7
Operating system and version (eg, Ubuntu 20.04): Alpine Linux
Apache or nginx version (eg, Apache 2.4.25): Nginx 1.20.2
PHP version (eg, 7.4): 8.0.14
I have successfully patched from Nextcloud 17 to Nextcloud 21.0.7.
In the administration page I find this security warning:
* Your web server is not properly set up to resolve "/.well-known/webfinger". Further information can be found in the [documentation](https://docs.nextcloud.com/server/21/go.php?to=admin-setup-well-known-URL).
* Your web server is not properly set up to resolve "/.well-known/nodeinfo". Further information can be found in the [documentation](https://docs.nextcloud.com/server/21/go.php?to=admin-setup-well-known-URL).
* Your web server is not properly set up to resolve "/.well-known/caldav". Further information can be found in the [documentation](https://docs.nextcloud.com/server/21/go.php?to=admin-setup-well-known-URL).
* Your web server is not properly set up to resolve "/.well-known/carddav". Further information can be found in the [documentation](https://docs.nextcloud.com/server/21/go.php?to=admin-setup-well-known-URL).
This server is running behind a forward proxy; I don’t know if this is related to the issue.
No
- Settings
- Administration > Overview
'passwordsalt' => '<passwordsalt>,
'secret' => '<secret>',
0 => '<cloud.mydomain.com>',
'apps_paths' =>
0 =>
'path' => '/var/www/nextcloud/apps',
'url' => '/apps',
'writable' => true,
'datadirectory' => '/var/lib/nextcloud/data',
'skeletondirectory' => '/var/lib/nextcloud/default_files',
'loglevel' => 2,
'knowledgebaseenabled' => true,
'check_for_working_htaccess' => false,
'version' => '21.0.7.0',
'overwrite.cli.url' => 'https://<cloud.mydomain.com>',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nc',
'dbpassword' => '<dbpassword>',
'integrity.check.disabled' => false,
'instanceid' => 'ochentz7kvhd',
'redis' =>
'host' => '/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
'theme' => '',
'twofactor_enforced' => 'true',
'app_install_overwrite' =>
0 => 'files_texteditor',
'encryption.legacy_format_support' => false,
'updater.secret' => '<updater.secret>',
2021/12/26 20:10:37 [error] 657#657: *11 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 10.0.0.10
0, server: cloud.mydomain.com, request: "GET /status.php HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "cloud.mydomain.com"
2021/12/26 20:10:37 [error] 657#657: *13 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 10.0.0.10
0, server: cloud.mydomain.com, request: "GET /nextcloud/status.php HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "cloud.mydomain.com"
2021/12/26 20:11:39 [error] 657#657: *15 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 10.0.0.10
2021/12/26 20:11:39 [error] 657#657: *17 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 10.0.0.10
2021/12/26 20:12:41 [error] 657#657: *19 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 10.0.0.10
2021/12/26 20:12:41 [error] 657#657: *21 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 10.0.0.10
2021/12/26 20:12:44 [error] 657#657: *23 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 10.0.0.10
0, server: cloud.mydomain.com, request: "PROPFIND /remote.php/dav/calendars/user/personal_shared_by_thomas/ HTTP/1.1", upstream: "fastcgi://
2021/12/26 20:12:44 [error] 657#657: *25 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: 10.0.0.10
0, server: cloud.mydomain.com, request: "PROPFIND /remote.php/dav/calendars/user/personal/ HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000",
2021/12/26 20:22:46 [error] 643#643: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 10.0.0.100, server: cloud.mydomain.com, request: "GET /settings/admin HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "cloud.mydomain.com"
2021/12/26 20:22:47 [error] 643#643: *3 connect() failed (111: Connection refused) while connecting to upstream, client: 10.0.0.100, server: cloud.mydomain.com, request: "PROPFIND /remote.php/dav/files/name/ HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "cloud.mydomain.com"
