Hi guys
So I wanted to start helping on the project. As you mention; just grab a ticket and get started! So I took a look at the Postgresql tickets. Like; 6343, 10473,9305
While I was trying to get comfortable I realized that @MorrisJobke is actively working on it at the moment. Is there any way I can support your efforts in a coordinated way? (Overview ticket)
Also is it correct, that the solution for now is to just keep the NC log clean and live with the clutter generated in the postgresql log?
I think some of the issues in the tickets mentioned above (apart from the already closed one) could be closed as well with the changes implemented so far.
Thanks a lot, I’m looking forward to learn something in the process!
