Nextcloud version (eg, 20.0.5): 24.0.3
Operating system and version (eg, Ubuntu 20.04): linuxserver/swag:latest image
Apache or nginx version (eg, Apache 2.4.25): linuxserver/swa: latest image
PHP version (eg, 7.4): linuxserver/swag:latest image
File validation fails after upgrade from 24.0.2
Steps to replicate it: ?
Results
- contacts
- EXTRA_FILE
- COPYING
Raw output
Array
[contacts] => Array
[EXTRA_FILE] => Array
[COPYING] => Array
[expected] =>
[current] => fff972ef22084a452a4e96210202261fb226982aa6a4941571702d6f786388e8f9a2a7e609d7c03a39fbcd31bf36307c9e20a074fe98b9247fb77d15df8a9776
'instanceid' => 'ocisn5okq4rq',
'passwordsalt' => '/vlPZX6YcyqjiZCB54ZheoIshPO7e0',
'secret' => '+FeX9tV0sUoE8BCz9nF9RWvgXyMcTrKNOxzvFw3MgDc0y2QH',
0 => 'nextcloud.gjmdmontferland.duckdns.org',
'datadirectory' => '/config/www/nextcloud/data',
'version' => '24.0.3.2',
'overwrite.cli.url' => 'https://nextcloud.gjmdmontferland.duckdns.org',
'dbname' => 'nextcloud',
'dbhost' => 'mariadb',
'dbuser' => 'nextcloud',
'dbpassword' => 'xxxxxxxx',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'dirksehome2.gjmdmontferland.nl',
'mail_smtphost' => 'dirksehome.gjmdmontferland.nl',
'app_install_overwrite' =>
0 => 'spgverein',
'theme' => '',
'loglevel' => 2,
'default_phone_region' => 'NL',
'updater.secret' => '$2y$10$YYn7zqfnVUCCi4ltXuJ1lOSRqT7zwmBN38P.1cOIXyOHVFJvV6Rie',
no entries
None
Documentation on this error is to contact support for the developer of contact.
