Using NGINX On Docker Containers
nginx
docker
nc15
#1
Having a small issue with some page assets not showing up after trying to get Nextcloud working through NGINX.
Was previously testing on NC 14, but NC 15 is also showing the exact same issue:
Nextcloud2
docker-compose.yml:
version: '2'
services:
  nextcloud:
    image: nextcloud:fpm-alpine
    dns: # Using Cloudflare DNS
      - 1.1.1.1
      - 1.0.0.1
    environment:
      MYSQL_HOST: mysql
      MYSQL_DATABASE: nextcloud
      MYSQL_USER: nextcloud_user
      MYSQL_PASSWORD: ${DB_USER_PASS}
      NEXTCLOUD_ADMIN_USER: ${NC_ADMIN}
      NEXTCLOUD_ADMIN_PASSWORD: ${NC_ADMIN_PASS}
    expose:
      - "80"
      - "9000"
    labels:
      io.rancher.container.pull_image: always
      {{- if .Values.HOST_LABEL}}
      io.rancher.scheduler.affinity:host_label: ${HOST_LABEL}
      {{- end}}
    networks:
      - public-proxy
    restart: on-failure
    volumes_from:
      - nginx
  nginx:
    image: nginx:latest # Can't use ":alpine" until I have a way to get the "www-data" user added automatically. (Project for another time)
      - 1.1.1.1
      - 1.0.0.1
    labels:
      {{- end}}
      io.rancher.sidekicks: nextcloud
      {{- if .Values.TRAEFIK_HOST}}
      traefik.enable: true
      ### Start Web Segment
      traefik.frontend.entryPoints: http,https
      traefik.frontend.headers.forceSTSHeader: true
      traefik.frontend.headers.referrerPolicy: no-referrer # Security enhancement (Prevents leaking of referer information)
      traefik.frontend.headers.SSLRedirect: true
      traefik.frontend.headers.STSPreload: true
      traefik.frontend.headers.STSSeconds: 15552000
      traefik.frontend.rule: Host:${TRAEFIK_HOST}
      traefik.port: "80"
      ### End Web Segment
      {{- else}}
      traefik.enable: false
      {{- end}}
    links:
      - mysql
      - nextcloud
      {{- if eq .Values.REDIS "true"}}
      - redis
      {{- end}}
    networks:
      - public-proxy
    {{- if .Values.WEB_PORT}}
    ports:
      - "${WEB_PORT}:80"
    {{- end}}
    restart: on-failure
    volumes:
      - /etc/localtime:/etc/localtime:ro # Syncronize time of container with the host system
      - /etc/timezone:/etc/timezone:ro # Syncronize timezone of container with the host system
      - /RancherCattle/${DATA_DIR}/Configuration/Nextcloud:/var/www/html/config # Nextcloud configuration files
      - /RancherCattle/${DATA_DIR}/Configuration/NGINX:/etc/nginx # NGINX configuration files
      - /RancherCattle/${DATA_DIR}/Apps:/var/www/html/custom_apps # Nextcloud apps
      - /RancherCattle/${DATA_DIR}/Nextcloud:/var/www/html # Nextcloud site
      - /RancherCattle/${DATA_DIR}/UserData:/var/www/html/data # Users' data file
  mysql:
    image: mysql:5
      - 1.1.1.1
      - 1.0.0.1
    environment:
      MYSQL_DATABASE: nextcloud # Will rename this to "nextcloud_db" in the future.
      MYSQL_ROOT_PASSWORD: ${DB_ROOT_PASS}
    labels:
      {{- end}}
    networks:
      db-admin:
        aliases:
          - nextcloud # This should allow access from "mysql.nextcloud.rancher.internal"
    restart: on-failure
    volumes:
      - /RancherCattle/${DATA_DIR}/Database:/var/lib/mysql
  redis:
    image: redis:latest
      - 1.1.1.1
      - 1.0.0.1
    labels:
      {{- end}}
    restart: on-failure
    volumes:
  {{- end}}
networks:
  db-admin:
    external: true # Created by phpMyAdmin stack
  public-proxy:
    external: true # Created by Traefik stack
nginx.conf:
user       www-data;
worker_processes  4;  ## Default: 1
# worker_rlimit_nofile 8192;
#error_log  /var/log/nginx/error.log warn;
#pid        /var/run/nginx.pid;
events {
    worker_connections  1024;  ## Default: 1024
http {
    include    /etc/nginx/mime.types;
    default_type application/octet-stream;
    #access_log  /var/log/nginx/access.log  main;
    sendfile     on;
    tcp_nopush   on;
    #keepalive_timeout  65;
    upstream php-handler {
        server nextcloud:9000;
    server {
        listen 80;
        listen [::]:80;
        server_name _;
        add_header X-Robots-Tag none;
        add_header Referrer-Policy no-referrer;
        # Remove X-Powered-By, which is an information leak
        root /var/www/html/;
        # Will test later
        #error_page 403 /core/templates/403.php;
        #error_page 404 /core/templates/404.php;
        location = /robots.txt {
            allow all;
            log_not_found off;
            access_log off;
        # set max upload size
        client_max_body_size 1G;
        fastcgi_buffers 64 4K;
        gzip on;
        gzip_vary on;
        gzip_comp_level 4;
        gzip_min_length 256;
        gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
        location / {
            rewrite ^ /index.php$request_uri;
            deny all;
            deny all;
        location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+)\.php(?:$|/) {
            # Mitigate https://httpoxy.org/ vulnerabilities:
            fastcgi_param HTTP_PROXY "";
            #fastcgi_index index.php;
            include fastcgi_params;
            fastcgi_pass php-handler;
            fastcgi_intercept_errors on;
        location ~ ^/(?:updater|ocs-provider)(?:$|/) {
            try_files $uri/ =404;
            index index.php;
        # Adding the cache control header for js and css files
        location ~ \.(?:css|js|woff2?|svg|gif)$ {
            add_header Cache-Control "public, max-age=15778463";
            access_log off;
        location ~ \.(?:png|html|ttf|ico|jpg|jpeg)$ {
            # Optional: Don't log access to other assets
            access_log off;
I assume it’s an issue with my NGINX configuration, but I’m not yet adept enough with it to figure it out.
Any help is greatly appreciated!
Thank you!
