We have a Nextcloud instance that’s been using Circles for a while and now we’d like to us Collectives too. My expectation was that existing circles would show up on the Collectives list, but that is not the case.
It appears that we’d have to create new collectives (which are visible as circles, but not vice-versa) but in doing so, we noticed that we cannot use existing Circle names since creating a collective also creates a circle of the same name.
I took a quick glance at the DB structure for both Circles and Collectives and it would appear that the Circles app consults the oc_collectives
table and those entries are not also added to the oc_circle_circles
table. The unique_id
in both cases don’t seem to have any kind of relationship either.
nextcloud=# select * from oc_collectives;
id | circle_unique_id | permissions | emoji | trash_timestamp
1 | xFDfMELibGbrDFVRhlsulMZhG1wvlDp | 3117 | 🥭 |
2 | dDZOFCMJRk1pQIZshkgx4hdsMJi9Q3s | 3131 | 🍦 |
(2 rows)
nextcloud=# select * from oc_circle_circles limit 2;
id | unique_id | long_id | name | alt_name | description | settings | type | creation | contact_addressbook | contact_groupname
1 | c465809af9b86e | c465809af9b86ee5b5eebe2f223800ec3846aa32de251c50 | Foobar | | | [] | 4 | 2021-01-08 14:52:20 | 0 |
42 | 7fcf1447b5768b | 7fcf1447b5768bdbc218816157d0f113999ae56880a04371 | Barbaz | | | [] | 4 | 2021-03-29 07:01:35 | 0 |
(2 rows)
In a nutshell, is there any way, automated or manual that we could import the existing circles into collectives or turn circles into collectives? Duplicating the circles or re-creating them using Collectives isn’t really a viable option.
Can @mejo maybe shed some light on this?
