Is it possible to use the camera and microphone via HTTP? Maybe some change in the code?
hey @Valdnet
what do you want to achieve by using http (without s)?
which app are you using? talk? in this case let me tell you that you most prolly won’t be able to establish a video/audio-connection with others outside of your lan. you’d need to setup your own co/turn-server being able to use that bonus. the forum would hint you to how to setup your own server.
best of luck
jimmy
nb: NC forces https for security reasons. i doubt someone would change the code to make it unsafe
Yes.
I understand that I will not be able to talk outside of the network. I am currently interested in talking to users without HTTPS.
OK. I will search.
