Users got disconnected from their data
    • 30.0.11
    • Ubuntu 24.04, fully updated
    • nginx
    • nginx
    • 8.3
    • yes
    • past 2 weeks
    • bare metal into a VM
    • yes
I recently decommissioned an old samba domain controller. I thought I had successfully migrated my users to a different LDAP (slapd)-based system. However, now when I log in, I am no longer connected to any of my files. Same for my other users. I’m guessing even though both users have/had the same userid, password, and email, nextcloud is using something else to build the UUID that connects a user to his/her data. Is there a way to re-attach the users?
My user (which should be an admin) now shows a bunch of default Nextcloud sample data in the web UI. Is there some patching up of my database I can do to reconnect the users correctly?
PASTE HERE
likely when you migrated to a new LDAP you didn’t just replace the connection but rather created new one so you had two separate LDAP connections. And for this reason user from “new LDAP server” are not the same as user from “old LDAP server”. if you still have the old LDAP in place likely the easiest way would be to update old ldap connection with new server.. if not there is a link, I think a table in the DB holding the connection between user@ldap1 ↔ user@nextcloud and you need to replace the link with the new server.
OK thanks very much. I needed to add the new connection as a separate one, since one was Active Directory and one was LDAP (though I know both are LDAP under the covers). I’ll look for through the tables in my server and try to find how to remap them.
