Actually forgot to mention: maps app was showing update available but update would never go through, kept giving error.
I updated maps app with solution from github
I’m sorry if I’m not understanding it correctly.
I’ll try to give kind of chronological steps:
Nextcloud instance showed notification about maps update available.
I tried updating by clicking on notification, that didn’t work (gave an error)
Searched around and found github issue
Used the solution mentioned:
sudo -u www-data php occ app:disable maps
cd apps
mv ./maps ./maps-old
wget https://github.com/nextcloud/maps/releases/download/v0.1.4/maps-0.1.4.tar.gz
tar -xzvf maps-0.1.4.tar.gz
chown -R www-data:www-data ./maps
cd ..
sudo -u www-data php occ app:enable maps
During this process I didn’t access maps app.
I didn’t put instance in maintenance mode because it was taking only few minutes
so I’m not entirely sure if other users were accessing maps app
Restored theme related settings to default because icons were not showing correctly.
I’m sorry took me a while to understand it.
But yes disabling maps app worked to get Users listed.
I’ll check with particular user if it resolves their login issue.
Glad to hear this helped you
If you experience sudden access problems to nextcloud it is always worth a try to disable the last updated apps, and if you don’t know which disable them all, try again and if it works enable them one by one until you find the “black sheep”.
