example
longer
example
here
Nextcloud version (eg, 20.0.5): 20.0.5
Operating system and version (eg, Ubuntu 20.04): Ubuntu 18.04
Apache or nginx version (eg, Apache 2.4.25): 2.4.48
PHP version (eg, 7.4): 7.4
After enabling the Extractor(?) add-on, I lost all access to the Nextcloud interface.
Is there a way for me to put nextcloud into maintenance mode via command line inferface so that I can upgrade Nextcloud 20.0.9 or or 21.0.?
Is this the first time you’ve seen this error? (Y/N):Y
- Go to URL cloud.esprimme.com
Here is a snippet from ../logs/access_log
[30/Apr/2021:19:26:06 -0400] "GET /index.php/204 HTTP/1.1" 500 4137 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.15.1"
173.238.111.22 - - [30/Apr/2021:19:26:06 -0400] "GET /index.php/204 HTTP/1.1" 500 4137 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.15.1"
173.238.106.177 - - [01/May/2021:11:24:28 -0400] "GET / HTTP/1.1" 500 4152 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:88.0) Gecko/20100101 Firefox/88.0"
'instanceid' => 'ocb06ckk12kr',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'cloud.esprimme.com',
'datadirectory' => '/home/cloud/public_html/data',
'version' => '20.0.5.2',
'overwrite.cli.url' => 'https://cloud.esprimme.com',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:3306',
'dbuser' => 'oc_esprimme',
'dbpassword' => 'xxx',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_from_address' => 'support',
'mail_domain' => 'esprimme.com',
'mail_smtphost' => 'mailout.easymail.ca',
'mail_smtpport' => '465',
'mail_smtpauth' => 1,
'mail_smtpname' => 'support@esprimme.com',
'mail_smtppassword' => **************
Don't know which log is needed...
