Hi. I’m wondering if there is any way to construct a url to a particular saved website entry? For example, if I have a username/password saved for amazon.com, is there any way to see that saved info with a url like /apps/passwords/#/site/amazon.com.
There is no “official” way for this, but you can use the global search for a similar effect. To do so, click on the search icon in the top right corner and then enter a search string that matches the password. Then hit “Enter” to use the global search. You will end up with an url like “https://example.com/index.php/apps/passwords/#/search/YW1hem9uLmNvbQ==”
