Nextcloud version (14.0.3):
Operating system and version (Debian9):
Apache or nginx version (2.4.25-3+deb9u5):
PHP version (1:7.0+49):
Upload error for files greater then few kb.
Is this the first time you’ve seen this error? (Y/N):Y
Fatal webdav Sabre\DAV\Exception\BadRequest: expected filesize 290824 got 49152
/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php - line 156:
OCA\DAV\Connector\Sabre\File->put(null)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 1096:
OCA\DAV\Connector\Sabre\Directory->createFile("Lumbricals_of_the_hand.png", null)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 529:
Sabre\DAV\Server->createFile("Temp-Testin ... g", null, null)
Sabre\DAV\CorePlugin->httpPut(Sabre\HTTP\R ... "}, Sabre\HTTP\Response {})
/var/www/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105:
call_user_func_array([ Sabre\DAV\ ... "], [ Sabre\HTTP ... }])
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 479:
Sabre\Event\EventEmitter->emit("method:PUT", [ Sabre\HTTP ... }])
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 254:
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\R ... "}, Sabre\HTTP\Response {})
/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php - line 80:
Sabre\DAV\Server->exec()
/var/www/nextcloud/remote.php - line 163:
require_once("/var/www/ne ... p")
'instanceid' => 'ocv0rvsiybom',
'passwordsalt' => 'x',
'secret' => 'x',
0 => 'cloud.x.eu',
1 => '10.1.2.11',
2 => '10.1.2.11',
3 => '10.1.1.11',
'overwrite.cli.url' => 'https://cloud.x.eu',
'version' => '14.0.3.0',
'dbname' => 'nextcloud',
'dbhost' => '10.1.1.14',
'dbuser' => 'nextcloud',
'dbpassword' => 'x',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'x.eu',
'mail_smtpsecure' => 'tls',
'mail_smtpauth' => 1,
'mail_smtphost' => 'mail.x.eu',
'mail_smtpport' => '587',
'mail_smtpname' => 'x@x.eu',
'mail_smtppassword' => x',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'enable_previews' => true,
'preview_max_x' => 2048,
'preview_max_y' => 2048,
'preview_max_scale_factor' => 10,
'preview_max_filesize_image' => 50,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\PNG',
1 => 'OC\\Preview\\JPEG',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\BMP',
4 => 'OC\\Preview\\XBitmap',
5 => 'OC\\Preview\\MP3',
6 => 'OC\\Preview\\TXT',
7 => 'OC\\Preview\\MarkDown',
8 => 'OCA\\CameraRawPreviews\\RawPreview',
9 => 'OCA\\CameraRawPreviews\\IndesignPreview',
'theme' => '',
'loglevel' => 2,
'auto_mail_accounts' =>
'imap_host' => 'imap.x.eu',
'imap_port' => '143',
'imap_ssl_mode' => 'STARTTLS',
'smtp_host' => 'smtp.x.eu',
'smtp_port' => '587',
'smtp_ssl_mode' => 'STARTTLS',
'email_address_suffix' => '',
10.1.1.1 - - [25/Oct/2018:14:59:52 +0200] "GET /index.php/apps/theming/img/core/filetypes/folder-drag-accept.svg?v=6 HTTP/1.1" 304 3859 "https://cloud.x.eu/index.php/apps/theming/styles?v=6" "Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/69.0.3497.100 Safari/537.36"
Would be nice to get some help, Thanks!
Maik
