Nextcloud version 12.0.3:
Operating system and version Debian 9.1:
nginx version __:
PHP version 7.0.19:
Is this the first time you’ve seen this error?: Yes
Can you reliably replicate it? (If so, please outline steps):
I have Installed a fresh Installation of Nextcloud on a Debian / Nginx php7-fpm with ISPConfig 3.1 Machine. everything works fine but i cant Upload any files. Nextcloud told me everytime: Theres not enough space for the files.
But my Settings allow 20G (for testing purpose)
By the way i CAN Upload anything with the nextcloud desktop client or android client. only WebInterface doesnt work.
And i can delet everything through the WebInterface
Zend OPcache can’t be temporary enabled (it may be only disabled till the end of request) at Unknown#0
internet_connection_check GuzzleHttp\Exception\RequestException: cURL error 18: transfer closed with 26500 bytes remaining to read
Nginx doesnt say any error or something in the log files
If you have some more questions feel free to ask
‘instanceid’ => ‘id?’,
‘passwordsalt’ => ‘salt’,
‘secret’ => ‘skey’,
‘trusted_domains’ =>
0 => ‘cloud.domain.com’,
‘datadirectory’ => ‘/var/www/clients/client1/web2/private/NXTData’,
‘overwrite.cli.url’ => ‘http://cloud.domain.com’,
‘dbtype’ => ‘mysql’,
‘version’ => ‘12.0.3.3’,
‘dbname’ => ‘’,
‘dbhost’ => ‘localhost’,
‘dbport’ => ‘’,
‘dbtableprefix’ => ‘oc_’,
‘mysql.utf8mb4’ => true,
‘dbuser’ => ‘’,
‘dbpassword’ => ‘’,
‘installed’ => true,
my nginx vhost:
add_header Strict-Transport-Security “max-age=15768000; includeSubDomains; preload;”;
add_header X-Frame-Options “SAMEORIGIN”;
add_header X-XSS-Protection “1; mode=block”;
add_header X-Robots-Tag none;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location ~ \.php$ {
try_files /642550b4c0a90e4013edb28d4df438a0.htm @php;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
location /.well-known/acme-challenge { }
# set max upload size
client_max_body_size 20G;
fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
gzip off;
# pagespeed off;
error_page 403 /core/templates/403.php;
error_page 404 /core/templates/404.php;
location / {
rewrite ^ /index.php$uri;
return 404;
return 404;
location ~ ^(.+?\.php)(/.*)?$ {
try_files $1 =404;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root$1;
fastcgi_param PATH_INFO $2;
fastcgi_param HTTPS $https;
{FASTCGIPASS}
fastcgi_intercept_errors on;
fastcgi_index index.php;
fastcgi_buffers 64 64K;
fastcgi_buffer_size 256k;
fastcgi_read_timeout 7200;
location @php2 {
fastcgi_split_path_info ^((?U).+\.php)(/?.+)$;
{FASTCGIPASS}
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
fastcgi_split_path_info ^(.+\.php)(/.*)$;
fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true; #Avoid sending the security headers twice
#fastcgi_pass php-handler;
#fastcgi_pass unix:/var/run/hhvm/hhvm.sock;
{FASTCGIPASS}
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
location ~* .(?:css|js)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control “public, max-age=7200”;
# Add headers to serve security related headers (It is intended to have those duplicated to the ones above)
# Before enabling Strict-Transport-Security headers please read into this topic first.
# add_header Strict-Transport-Security “max-age=15768000; includeSubDomains; preload;”;
# Optional: Don’t log access to assets
access_log off;
location ~* .(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$ {
# Optional: Don’t log access to other assets
access_log off;
location = /data/htaccesstest.txt {
allow all;
log_not_found off;
access_log off;
