Nextcloud version: 15.0.2
Operating system and version : Debian 9.7
Apache or nginx version: Apache 2.4.25
PHP version: 7.2
Upload onto Nextcloud is significantly slower using Firefox or Chrome (25 Mbit/s) as compared to Internet Explorer (90 Mbit/s).
Is this the first time you’ve seen this error?: Yes
- setup large file upload according to documentation
- Login to Nextcloud via Firefox/Chrome
- Upload large File (>500 MB)
- Check upload speed (e.g. with TaskManager) -> speed only 25% of max upload speed
- Login to Nextcloud via internet exporer
- Check upload speed (e.g. with TaskManager) -> speed 90-100% of max upload speed
no log errors
I dug up this issue from 2017 which saw a similar behavior under Nextcloud 11.
Any ideas what could be the cause of that?
Is there any configuration specific to Firefox/Chrome that would make it slower?
It just cannot be that IE is better at something
