Does someone know a plugin for shutter (Linux) screenshotprogram to upload screenshots to nextcloud and have the link in the program available?
Maybe helpful pluginwritingtemplate: http://j.mp/2xRQzLe
Isn’t putting the screenshot folder as a sync folder with the nextcloud app a working solution?
Not realy. Many steps are requierd
Make screenscot - Open Nemo - Search the folder - Search the last saved file - Rightclick and open sharedialog - Copy url to clipboard
ah ok, I see you want a imgur like behavior in shutter. That would be interesting.
Yes, that would be great. But i have no idea how to do this.
Reviving this thread to discuss options…
