Hello Dear Community,
I have a dedicated server running Nextcloud 12.0.3 on it. It also works in and of itself.
I’m just having some minor technical difficulties.
So the server is a:
Debian 9.1 Server
nginx/1.12.1
PHP7-fpm
ISPConfig 3.1.7p1
bind9
What works. I can use the “Sync your data” apps for desktop and Android to store and delete files on the cloud. Absolutely no problem.
Which doesn’t work. When I try to save files via the browser, it doesn’t work. It is said (something like this, at least):
You want to save a 1.5 MB file but there is not enough free space available. 0Bytes
I don’t get any error messages in the log files everything seems to work smoothly.
The only thing I get in the Acces. log is this when I upload a 0-byte file:
xxx. xxx. xxx. xxx. xxx - - - -[07/Oct/2017:19:51:13 +0200]"GET /core/preview. png? file=%2F%2FNew+textdocument+ (3. txt&x=96&y=96&c=cec4c966d8800212d3719faacfb773c2&forceIcon
xxx. xxx. xxx. xxx. xxx - - - -[07/Oct/2017:19:51:16 +0200]“PUT /remote. php/webdav/New%20Textdocument%20 (3). txt HTTP/1.1” 204 0 “-”"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like
77.21.32.94 - - -[07/Oct/2017:19:51:16 +0200]“PROPFIND /remote. php/webdav/New%20Textdocument%20 (3. txt HTTP/1.1” 207 902 “-”"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like G
xxx. xxx. xxx. xxx. xxx - - - -[07/Oct/2017:19:51:20 +0200]“GET /ocs/v2. php/apps/notifications/api/v2/notifications HTTP/1.1” 200 1484 “-”"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like G
When I upload a 1.6MB file I only get the message “there is no storage space”. There are no entries in the logs.
However, Nextcloud tells me in the log that:
Zend OPcache can’t be temporary enabled (it may be only disabled to the end of request) at Unknown#0
and
GuzzleHttp\Exception\ExceptionRequestException: cURL error 18: transfer closed with 26500 bytes remaining to read
But what I find amazing is that I can upload a 0Byte file without any problems.
I also noticed that I can’t install apps automatically through the web interface. I guess it’s also because of this problem.
Here’s my VHost for Nginx:
#add_header X-Frame-Options "SAMEORIGIN";
add_header X-Robots-Tag none;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json
# last;
# set max upload size
client_max_body_size 8G;
fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
gzip off;
#pagespeed off;
location = / {
index index.php index.html;
location / {
rewrite ^ /index.php$uri;
deny all;
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/t$/40[34])\.php(?:$|/) {
fastcgi_split_path_info ^(.+\.php)(/.*)$;
include snippets/fastcgi-php.conf;
fastcgi_param HTTPS on;
#fastcgi_pass php-handler;
{FASTCGIPASS}
fastcgi_intercept_errors on;
# Cache
#fastcgi_cache_bypass #skip_cache;
#fastcgi_no_cache $skip_cache;
#fastcgi_cache cloud.ryztec.com;
#fastcgi_cache_valid 60m;
#fastcgi_cache_methods GET HEAD;
# Cache purging
fastcgi_cache_key $http_cookie$request_method$host$request_uri;
fastcgi_cache_use_stale error timeout invalid_header http_500;
fastcgi_ignore_headers Cache-Control Expires Set-Cookie;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
location ~* \.(?:css|js|woff|svg|gif)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=7200";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
# Before enabling Strict-Transport-Security headers please read into
# this topic first.
add_header Strict-Transport-Security "max-age=15768000";
# includeSubDomains; preload;";
access_log off;
location ~* \.(?:png|html|ttf|ico|jpg|jpeg)$ {
# Optional: Don't log access to other assets
access_log off;
Before I forget to mention it. the same configuration works with Apache.
Could it be due to the CHMOD settings?
I mean, ISPConfig creates users and groups, for example:
Group: client1
Owner: web1
Is it because of the permissions that php7-fpm cannot access it?
