example
longer
example
here
Nextcloud version (eg, 20.0.5): 22.0.0
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.2 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.41 (Ubuntu)
PHP version (eg, 7.4): PHP 7.4.3
The Nextcloud windows client is saying;
Server replied “403 Forbidden” to “MKCOL https://fqdn/remote.php/dav/files/<username & folder>”
When I try to look for logs only the system and use ‘sudo -i’ it runs the initial script from tech and me.
FWIW - I recreated the system in October last year - I think on v19 and subsequently updated to v20 iirc.
This weekend I planned to update to v21 but it was erroring because v22 is released.
I followed the instructions to run the built-in upgrade CLI which was able to update the v21.x after I chown’d the folder;
sudo chown www-data:www-data -R /var/www/nextcloud
Then I ran the update again to update to v22 and it re-adjusted the permissions
sudo bash /var/scripts/update.sh
- observe faults in the windows sync client
- try to run sudo -i in the console
unable to retrieve at the moment because of the sudo issue
PASTE HERE
PASTE HERE
