Upgrade to 28 - Admin Overview not seeing sodium module installed
example
longer
example
here
Nextcloud 28.0.1
Archlinux: 6.6.10-arch1-1
Apache / 2.4.58 (Unix)
OpenSSL / 3.2.0
PHP / 8.1.27
This may be a regression as it is similar to Missing PHP Module sodium from Ver. 22 days.
After upgrade to 28 (from 27) the Admin->Overview check recommended:
This instance is missing some recommended PHP modules. For improved performance and better compatibility it is highly recommended to install them: sodium. For more details see the documentation ↗.
So I installed php-sodium and enabled the module – and confirmed it was enabled in php:
# php-legacy -m | grep -i sodium
sodium
  1. Update to 28.0.1 from 27.0.4
  2. Check Admin->Overview, complains php-sodium not installed
  3. Install/Enable php-sodium
  4. It doesn’t fix 2. above
{"reqId":"qdaVUkWP6Fk2fSmvcmPe","level":3,"time":"2024-01-13T03:36:49+00:00","remoteAddr":"192.168.6.104","user":"david","app":"PHP","method":"GET","url":"/nextcloud/ocs/v2.php/search/providers?from=%2Fnextcloud%2Fsettings%2Fuser%2Fsecurity","message":"Module \"apcu\" is already loaded at Unknown#0","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0","version":"28.0.1.1","data":{"app":"PHP"}}
{"reqId":"QSQfhG45OFYMRneu7dA5","level":3,"time":"2024-01-13T03:37:19+00:00","remoteAddr":"192.168.6.104","user":"david","app":"PHP","method":"GET","url":"/nextcloud/apps/theming/theme/light.css?plain=0&v=c973a648","message":"Module \"apcu\" is already loaded at Unknown#0","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0","version":"28.0.1.1","data":{"app":"PHP"}}
{"reqId":"jm3fAimSuEIaZlpT9Xhg","level":3,"time":"2024-01-13T03:37:43+00:00","remoteAddr":"192.168.6.104","user":"david","app":"PHP","method":"GET","url":"/nextcloud/ocs/v2.php/search/providers?from=%2Fnextcloud%2Fsettings%2Fadmin%2Flogging","message":"Module \"apcu\" is already loaded at Unknown#0","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0","version":"28.0.1.1","data":{"app":"PHP"}}
{"reqId":"Dtj1pNTnQCSjuoYdfSJ0","level":3,"time":"2024-01-13T03:43:08+00:00","remoteAddr":"192.168.6.104","user":"david","app":"PHP","method":"PROPFIND","url":"/nextcloud/remote.php/dav","message":"Module \"apcu\" is already loaded at Unknown#0","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/115.0","version":"28.0.1.1","data":{"app":"PHP"}}
Nothing but the annoying "message":"Module \"apcu\" is already loaded at Unknown#0" that has been there since my first Nextcloud install.
        "logfile": "\/var\/log\/nextcloud\/nextcloud.log",
        "default_locale": "en_US",
        "default_phone_region": "US",
        "knowledgebaseenabled": true,
        "apps_paths": [
                "path": "\/usr\/share\/webapps\/nextcloud\/apps",
                "url": "\/apps",
                "writable": false
                "path": "\/var\/lib\/nextcloud\/apps",
                "url": "\/wapps",
                "writable": true
            "localhost",
            "host.domain.tld",
            "192.168.6.111"
        "overwrite.cli.url": "https:\/\/2pi.3111skyline.com\/nextcloud",
        "htaccess.RewriteBase": "\/nextcloud",
        "dbtype": "mysql",
        "version": "28.0.1.1",
        "dbport": "",
        "mysql.utf8mb4": true,
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "25",
        "app_install_overwrite": [
            "issuetemplate",
            "holiday_calendars"
        "theme": "",
        "loglevel": 2,
        "filelocking.enabled": true,
        "redis": {
            "port": 0,
            "timeout": 0
[Fri Jan 12 21:18:03.762302 2024] [core:notice] [pid 423] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Fri Jan 12 21:21:14.243651 2024] [mpm_prefork:notice] [pid 423] AH00171: Graceful restart requested, doing restart
[Fri Jan 12 21:21:14.311406 2024] [mpm_prefork:notice] [pid 423] AH00163: Apache/2.4.58 (Unix) OpenSSL/3.2.0 PHP/8.1.27 configured -- resuming normal operations
[Fri Jan 12 21:21:14.311432 2024] [core:notice] [pid 423] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Fri Jan 12 21:22:21.970102 2024] [mpm_prefork:notice] [pid 423] AH00171: Graceful restart requested, doing restart
[Fri Jan 12 21:22:22.060488 2024] [mpm_prefork:notice] [pid 423] AH00163: Apache/2.4.58 (Unix) OpenSSL/3.2.0 PHP/8.1.27 configured -- resuming normal operations
[Fri Jan 12 21:22:22.060513 2024] [core:notice] [pid 423] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
[Fri Jan 12 21:43:00.293497 2024] [mpm_prefork:notice] [pid 423] AH00171: Graceful restart requested, doing restart
[Fri Jan 12 21:43:00.371804 2024] [mpm_prefork:notice] [pid 423] AH00163: Apache/2.4.58 (Unix) OpenSSL/3.2.0 PHP/8.1.27 configured -- resuming normal operations
[Fri Jan 12 21:43:00.371831 2024] [core:notice] [pid 423] AH00094: Command line: '/usr/bin/httpd -D FOREGROUND'
None
How do I satisfy the warning that sodium is really installed?
This appears to have been an Archlinux packaging issue. Thankfully it has now been resolved with an update.
