Environment:
- Upgrade Nextcloud Server version 34.0.4 → 35.0.2
- running NC as Container
- MariaDB 11.8 - also Container
- Container running on a Synology
Problem:
During the upgrade from 34.0.4 to 35.0.2 i run in the failure message
“rsync: [generator] delete_file: rmdir(custom_tmp) failed: Device or resource busy (16)”
So the upgrade cant finish and service is in maintenance and cant be used.
What i try:
- The folder custom_tmp exist and is removable (if i remove this folder manualy and restart container than folder will be created new) .
- I switched back to 34.0.4 - but DB Shema is always 35.x - so this is not running anymore (a lot of missing tables and unknown tables)
- working on CLI in NC Container is nearly impossible because of internal container restart
- I cant found a "force"upgrade nor a skip of the rsync…
I have no idea what i can try. Any hints?
best regards,
Mike
