example
longer
example
here
Nextcloud version 17.0.1:
Operating system and version Plesk Obsidian v18.0.21_build1800191115.23 os_CentOS 7 on CentOS Linux 7.7.1908 (Core):
PHP version 7.3.11:
After the upgrade from 16 to 17.0.1:
The output of Nextcloud upgrade page
Authentication
To login you need to provide the unhashed value of "updater.secret" in your config file.
If you don't know that value, you can access this updater directly via the Nextcloud admin screen or generate your own secret:
php -r '$password = trim(shell_exec("openssl rand -base64 48"));if(strlen($password) === 64) {$hash = password_hash($password, PASSWORD_DEFAULT) . "\n"; echo "Insert as \"updater.secret\": ".$hash; echo "The plaintext value is: ".$password."\n";}else{echo "Could not execute OpenSSL.\n";};'
I tried several times to create the secret key and insert it into the config file, but it is always rejected.
