Updating Nextcloud problem: "Update in process."
Hi everyone,
I was updating nextcloud because my host has removed the php version that was compatible with my nextcloud. The update seems to have had some problems.
Now my nextcloud page is always saying “Update in process.” and I do not know what to do. I am not a very technical person and do not have a lot of experience with hosts and so on. I just run next cloud to help me with my calendars.
So, if anyone can help me getting unstuck that would be great. I probably need a detailed step by step instruction as i lack the background to do so otherwise.
thank you so much to anyone who helps out :slight_smile:
Sometimes it helps to delete, rename or manipulate the file .step in the updater directory.
