example
longer
example
here
Nextcloud version (eg, 12.0.2): I think 16, maybe 17. Not entirely sure, and hard to check atm.
Operating system and version (eg, Ubuntu 17.04): Debian 9
Apache or nginx version (eg, Apache 2.4.25): apache 2.4.x
PHP version (eg, 7.1): 7.3.x
The issue you are facing: nextcloud web interface does not load. I get the following on a webpage when trying to access locally or remotely:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
Is this the first time you’ve seen this error? (Y/N): yes
- open any web browser
- go to my domain OR even local ip address.
{"reqId":"hR4m8reBUM2c4RFv44ui","level":2,"time":"2020-01-10T17:15:06+00:00","remoteAddr":"","user":"--","app":"OC\\Log\\Rotate","method":"","url":"--","message":"Log file \"\/var\/www\/nextcloud\/data\/nextcloud.log\" was over 104857600 bytes, moved to \"\/var\/www\/nextcloud\/data\/nextcloud.log.1\"","userAgent":"--","version":"16.0.5.1"}
{"reqId":"N8P8vzXfsewisqVnavl7","level":3,"time":"2020-01-10T17:15:23+00:00","remoteAddr":"192.168.1.7","user":"esteban","app":"no app in context","method":"GET","url":"\/ocs\/v2.php\/apps\/notifications\/api\/v2\/notifications","message":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"ocs.provisioning_api.AppsController.disable\" as such route does not exist.","Code":0,"Trace":[{"file":"\/var\/www\/nextcloud\/lib\/private\/Route\/Router.php","line":337,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["ocs.provisioning_api.AppsController.disable",{"app":"nextcloud_announcements"},1]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Route\/CachingRouter.php","line":60,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["ocs.provisioning_api.AppsController.disable",{"app":"nextcloud_announcements"},false]},{"file":"\/var\/www\/nextcloud\/lib\/private\/URLGenerator.php","line":95,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["ocs.provisioning_api.AppsController.disable",{"app":"nextcloud_announcements"},false]},{"file":"\/var\/www\/nextcloud\/apps\/nextcloud_announcements\/lib\/Notification\/Notifier.php","line":89,"function":"linkToOCSRouteAbsolute","class":"OC\\URLGenerator","type":"->","args":["provisioning_api.AppsController.disable",{"app":"nextcloud_announcements"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Notification\/Manager.php","line":226,"function":"prepare","class":"OCA\\NextcloudAnnouncements\\Notification\\Notifier","type":"->","args":[{"__class__":"OC\\Notification\\Notification"},"en"]},{"file":"\/var\/www\/nextcloud\/apps\/notifications\/lib\/Controller\/EndpointController.php","line":92,"function":"prepare","class":"OC\\Notification\\Manager","type":"->","args":[{"__class__":"OC\\Notification\\Notification"},"en"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php","line":166,"function":"listNotifications","class":"OCA\\Notifications\\Controller\\EndpointController","type":"->","args":["v2"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php","line":99,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Notifications\\Controller\\EndpointController"},"listNotifications"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/App.php","line":126,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Notifications\\Controller\\EndpointController"},"listNotifications"]},{"file":"\/var\/www\/nextcloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php","line":47,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Notifications\\Controller\\EndpointController","listNotifications",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"apiVersion":"v2","_route":"ocs.notifications.Endpoint.listNotifications"}]},{"function":"__invoke","class":"OC\\AppFramework\\Routing\\RouteActionHandler","type":"->","args":[{"apiVersion":"v2","_route":"ocs.notifications.Endpoint.listNotifications"}]},{"file":"\/var\/www\/nextcloud\/lib\/private\/Route\/Router.php","line":297,"function":"call_user_func","args":[{"__class__":"OC\\AppFramework\\Routing\\RouteActionHandler"},{"apiVersion":"v2","_route":"ocs.notifications.Endpoint.listNotifications"}]},{"file":"\/var\/www\/nextcloud\/ocs\/v1.php","line":82,"function":"match","class":"OC\\Route\\Router","type":"->","args":["\/ocsapp\/apps\/notifications\/api\/v2\/notifications"]},{"file":"\/var\/www\/nextcloud\/ocs\/v2.php","line":24,"args":["\/var\/www\/nextcloud\/ocs\/v1.php"],"function":"require_once"}],"File":"\/var\/www\/nextcloud\/3rdparty\/symfony\/routing\/Generator\/UrlGenerator.php","Line":130,"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (Macintosh; Intel Mac OS X 10.14; rv:71.0) Gecko\/20100101 Firefox\/71.0","version":"16.0.5.1"}
'passwordsalt' => '*******',
'secret' => '*********',
0 => '*******.com',
1 => 'cloud.*********.com',
2 => '192.168.1.666',
'overwrite.cli.url' => 'https://*********.com/nextcloud',
'version' => '16.0.5.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'instanceid' => 'oc6dy44diqh4',
'dbuser' => 'oc_someUser',
'dbpassword' => '******',
'theme' => '',
'loglevel' => 2,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => '******',
'mail_domain' => '**********.com',
'mail_smtpauth' => 1,
'mail_smtphost' => '**********.com',
'mail_smtpport' => '465',
'mail_smtpname' => '***********',
'mail_smtppassword' => '***********',
'app_install_overwrite' =>
0 => 'calendar',
1 => 'spreed',
2 => 'mail',
[Sun Feb 16 15:06:29.997257 2020] [php7:error] [pid 1341] [client 192.168.1.7:51973] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(448): OC\\DB\\Connection->connect()\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(410): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(354): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(710): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(181): OC\\DB\\Connection->__construct(Array, Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Ob in /var/www/nextcloud/lib/private/DB/Connection.php on line 64
[Sun Feb 16 15:06:30.012751 2020] [php7:error] [pid 1341] [client 192.168.1.7:51973] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(448): OC\\DB\\Connection->connect()\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(410): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(354): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(710): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(181): OC\\DB\\Connection->__construct(Array, Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Ob in /var/www/nextcloud/lib/private/DB/Connection.php on line 64
[Sun Feb 16 15:06:30.858151 2020] [php7:error] [pid 8150] [client 192.168.1.6:39974] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(448): OC\\DB\\Connection->connect()\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(410): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(354): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(710): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(181): OC\\DB\\Connection->__construct(Array, Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Ob in /var/www/nextcloud/lib/private/DB/Connection.php on line 64
[Sun Feb 16 15:06:30.858649 2020] [php7:error] [pid 8150] [client 192.168.1.6:39974] PHP Fatal error: Uncaught Doctrine\\DBAL\\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2002] No such file or directory in /var/www/nextcloud/lib/private/DB/Connection.php:64\nStack trace:\n#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(448): OC\\DB\\Connection->connect()\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(410): Doctrine\\DBAL\\Connection->getDatabasePlatformVersion()\n#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(354): Doctrine\\DBAL\\Connection->detectDatabasePlatform()\n#3 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(710): Doctrine\\DBAL\\Connection->getDatabasePlatform()\n#4 /var/www/nextcloud/lib/private/DB/Connection.php(151): Doctrine\\DBAL\\Connection->setTransactionIsolation(2)\n#5 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(181): OC\\DB\\Connection->__construct(Array, Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Ob in /var/www/nextcloud/lib/private/DB/Connection.php on line 64
