- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can.
Server configuration detail
Operating system: Linux 5.15.0-126-generic #136-Ubuntu SMP Wed Nov 6 10:38:22 UTC 2024 x86_64
Webserver: Apache/2.4.52 (Ubuntu) (fpm-fcgi)
Database: mysql 10.6.18
PHP version: 8.2.24
Modules loaded: Core, date, libxml, openssl, pcre, zlib, filter, hash, json, random, Reflection, SPL, session, standard, sodium, cgi-fcgi, mysqlnd, PDO, xml, bcmath, calendar, ctype, curl, dom, mbstring, FFI, fileinfo, ftp, gd, gettext, gmp, iconv, igbinary, imagick, intl, exif, mysqli, pdo_mysql, Phar, posix, readline, shmop, SimpleXML, sockets, sysvmsg, sysvsem, sysvshm, tokenizer, xmlreader, xmlwriter, xsl, zip, redis, Zend OPcache
Nextcloud version: 30.0.4 - 30.0.4.1
Updated from an older Nextcloud/ownCloud or fresh install:
Where did you install Nextcloud from: unknown
Signing status
List of activated apps
- activity: 3.0.0
- admin_audit: 1.20.0
- app_api: 4.0.3
- bruteforcesettings: 3.0.0
- calendar: 5.0.6
- circles: 30.0.0
- comments: 1.20.1
- contacts: 6.1.1
- contactsinteraction: 1.11.0
- dashboard: 7.10.0
- dav: 1.31.1
- federation: 1.20.0
- files: 2.2.0
- files_downloadlimit: 3.0.0
- files_pdfviewer: 3.0.0
- files_reminders: 1.3.0
- files_sharing: 1.22.0
- files_trashbin: 1.20.1
- files_versions: 1.23.0
- fileslibreofficeedit: 2.0.1
- firstrunwizard: 3.0.0
- logreader: 3.0.0
- notifications: 3.0.0
- oauth2: 1.18.1
- password_policy: 2.0.0
- photos: 3.0.2
- privacy: 2.0.0
- provisioning_api: 1.20.0
- recommendations: 3.0.0
- related_resources: 1.5.0
- richdocuments: 8.5.3
- richdocumentscode: 24.4.1002
- serverinfo: 2.0.0
- settings: 1.13.0
- sharebymail: 1.20.0
- support: 2.0.0
- survey_client: 2.0.0
- systemtags: 1.20.0
- text: 4.1.0
- theming: 2.5.0
- updatenotification: 1.20.0
- user_status: 1.10.0
- viewer: 3.0.0
- weather_status: 1.10.0
- workflowengine: 2.12.0
- camerarawpreviews: 0.8.6
- custom_whitelist: 1.0.0
- documents
- encryption
- files_external
- files_rightclick: 1.6.0
- music: 2.0.1
- spreed: 20.0.2
- suspicious_login
- twofactor_nextcloud_notification
- twofactor_totp
- unsplash: 3.0.3
- user_ldap
- wopi: 3.5.11
Configuration (config/config.php)
"192.168.0.12",
"mycloud.cloudns.ph",
"localhost",
"127.0.0.1",
"79.107.132.159",
"10.245.30.8",
"10.229.189.125",
"91.140.28.187",
"10.228.100.162",
"www.mycloud.cloudns.ph",
"localhost"
"forwarded_for_headers": [
"HTTP_X_FORWARDED_FOR",
"HTTP_FORWARDED"
"tempdirectory": "\/var\/www\/html\/nextcloud\/tmp",
"default_locale": "en_US",
"default_timezone": "Europe\/Athens",
"overwritehost": "mycloud.cloudns.ph",
"overwriteprotocol": "https",
"dbtype": "mysql",
"version": "30.0.4.1",
"overwrite.cli.url": "https:\/\/mycloud.cloudns.ph\/",
"htaccess.RewriteBase": "\/",
"memory_limit": "4096M",
"dbport": "",
"mysql.utf8mb4": true,
"default_phone_region": "GR",
"theme": "",
"loglevel": 1,
"enable_previews": false,
"filelocking.enabled": "true",
"redis": {
"port": 6379,
"timeout": 0,
"dbindex": 0
"0": [
"documentserver_community"
"mail_smtpmode": "smtp",
"mail_sendmailmode": "smtp",
"mail_smtpport": "465",
"mail_smtpauth": 1,
"mail_smtpstreamoptions": {
"ssl": {
"allow_self_signed": true,
"verify_peer": false,
"verify_peer_name": false
"mail_smtpsecure": "ssl",
"app_install_overwrite": [
"documents",
"wopi"
Cron Configuration: Array ( [backgroundjobs_mode] => cron [lastcron] => 1734089403 )
External storages: files_external is disabled
Encryption: no
User-backends:
- OC\User\Database
Subscription:
- No valid subscription key set
Browser: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36
During update the installer stopped because there was a tmp folder in the insatallation path. So I moved it to other place. But I can’t login. The credentials are correct and the page just refreshes and askes again for the credentials.
When I move the folder back into the installation path then login is possible. Is that normal?
[PHP] Error: session_start(): Failed to read session data: files (path: /var/www/html/nextcloud/tmp) at /var/www/html/nextcloud/lib/private/Session/Internal.php#198
GET /index.php/apps/files/preview-service-worker.js
from 37.6.162.39 by – at 13 Δεκ 2024, 1:31:53 μ.μ.
[PHP] Error: session_start(): open(/var/www/html/nextcloud/tmp/sess_j07rs9v0h5pf4q3g1jbv3hb3i3, O_RDWR) failed: No such file or directory (2) at /var/www/html/nextcloud/lib/private/Session/Internal.php#198
