Update problems after swtiching from Nextcloud 16.0.x to 16.0.3 with the groupfolders plugin.
SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘acl’ in ‘field list’
Nextcloud version : 16.0.3
Operating system and version : Debian 9
Apache or nginx version : included in Docker image 16.0.3
PHP version : included in Docker image 16.0.3
I pulled the new image and restarted the containers and that worked pretty fine.
After that I tried to patch every single plugin. Also here every plugin worked up to the groupfolders plugin.
After updating and enabling the groupfolders plugin Nextcloud is showing an 500 message, with the info I should contact the administrator.
After manually disabling the groupfolder plugin over the occ cli the Nextcloud backend was again working and I was able to visit the settings over the webbrowser.
I detected errors for the app “index” in the settings/admin/logging page and I think there is something wrong in the database. I also tried to fix it with a occ repair command, but this did not help. Also I tried to reinstall the groupfolders plugin.
- Patched to 16.0.3
- Restarted Containers
- Updated groupfolder plugin
[index] Error: Doctrine\DBAL\Exception\InvalidFieldNameException: An exception occurred while executing 'SELECT `f`.`folder_id`, `mount_point`, `quota`, `acl`, `fileid`, `storage`, `path`, `name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `etag`, `encrypted`, `parent`, `a`.`permissions` AS `group_permissions`, `c`.`permissions` AS `permissions` FROM `oc_group_folders` `f` INNER JOIN `oc_group_folders_groups` `a` ON `f`.`folder_id` = `a`.`folder_id` LEFT JOIN `oc_filecache` `c` ON (`name` = CONCAT(`f`.`folder_id`, '')) AND (`parent` = ?) WHERE `a`.`group_id` = ?' with params [1013797, "admin"]:
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'acl' in 'field list' at <<closure>>
0. /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php line 184
Doctrine\DBAL\Driver\AbstractMySQLDriver->convertException("An exception oc ... '", Doctrine\DBAL\Dr ... ]})
1. /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php line 158
Doctrine\DBAL\DBALException::wrapException(Doctrine\DBAL\Driver\PDOMySql\Driver {}, Doctrine\DBAL\Dr ... ]}, "An exception oc ... '")
2. /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php line 938
Doctrine\DBAL\DBALException::driverExceptionDuringQuery(Doctrine\DBAL\Driver\PDOMySql\Driver {}, Doctrine\DBAL\Dr ... ]}, "SELECT `f`.`fol ... ?", {1: 1013797,2: " ... "})
3. /var/www/html/lib/private/DB/Connection.php line 195
Doctrine\DBAL\Connection->executeQuery("SELECT `f`.`fol ... ?", [1013797,"*** se ... "], [2,2], null)
4. /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php line 219
OC\DB\Connection->executeQuery("SELECT `f`.`fol ... 1", {dcValue1: "*** ... 7}, {dcValue1: 2,dcValue2: 2})
5. /var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php line 214
Doctrine\DBAL\Query\QueryBuilder->execute()
6. /var/www/html/apps/groupfolders/lib/Folder/FolderManager.php line 241
OC\DB\QueryBuilder\QueryBuilder->execute()
7. /var/www/html/apps/groupfolders/lib/Folder/FolderManager.php line 358
OCA\GroupFolders\Folder\FolderManager->getFoldersForGroup("*** sensitive parameter replaced ***", 8)
8. <<closure>>
OCA\GroupFolders\Folder\FolderManager->OCA\GroupFolders\Folder\{closure}("*** sensitive parameters replaced ***")
9. /var/www/html/apps/groupfolders/lib/Folder/FolderManager.php line 359
undefinedundefinedarray_reduce(["*** sensitive parameter replaced ***"], Closure {}, "*** sensitive parameter replaced ***")
10. /var/www/html/apps/groupfolders/lib/Mount/MountProvider.php line 82
OCA\GroupFolders\Folder\FolderManager->getFoldersForUser(OC\User\User {}, 8)
11. /var/www/html/apps/groupfolders/lib/Mount/MountProvider.php line 86
OCA\GroupFolders\Mount\MountProvider->getFoldersForUser(OC\User\User {})
12. /var/www/html/lib/private/Files/Config/MountProviderCollection.php line 103
OCA\GroupFolders\Mount\MountProvider->getMountsForUser(OC\User\User {}, OC\Files\Storage\StorageFactory {})
13. /var/www/html/lib/private/Files/Filesystem.php line 447
OC\Files\Config\MountProviderCollection->addMountForUser(OC\User\User {}, OC\Files\Mount\Manager {})
14. /var/www/html/lib/private/Files/Filesystem.php line 376
OC\Files\Filesystem::initMountPoints("nextcloud")
15. /var/www/html/lib/private/legacy/util.php line 309
OC\Files\Filesystem::init("nextcloud", "/nextcloud/files")
16. /var/www/html/lib/base.php line 974
OC_Util::setupFS()
17. /var/www/html/index.php line 42
OC::handleRequest()
GET /index.php/settings/admin/undefined/img/notifications.svg
from 192.168.0.35 by nextcloudat 2019-07-25T09:42:46+00:00
'instanceid' => 'xx',
'passwordsalt' => 'xx',
'secret' => 'xx',
'auth.bruteforce.protection.enabled' => false,
// 0 => 'xx',
0 => '*', // for debugging directly over IP
'skeletondirectory' => '',
'overwrite.cli.url' => 'https://xx',
'version' => '16.0.3.0',
'dbname' => 'nextcloud',
'dbhost' => 'nextcloud.mariadb',
'dbport' => '3401',
'dbuser' => 'xx',
'dbpassword' => 'xx',
'mail_from_address' => 'support',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'xx',
'mail_smtphost' => 'xx',
'mail_smtpport' => '587',
'mail_smtpsecure' => 'tls',
'mail_smtpauth' => 1,
'mail_smtpname' => 'xx',
'mail_smtppassword' => 'xx',
'redis' =>
'host' => 'nextcloud.redis',
'port' => 6379,
'loglevel' => 0,
'theme' => '',
'app_install_overwrite' =>
0 => 'twofactor_totp',
1 => 'bookmarks_fulltextsearch',
2 => 'admin_notifications',
I think it is a small step by adding the columns, but I’m not really sure which table is affected.
Because there are a few tables with similar names. And there is also an “acl” folder, so I wanted to ask before I try to fix something.
Thanks a lot.
