Leider klappt das Update auf Version 25.0.5 nicht.
Nach dem Update kommt folgende Meldung:
Interner Serverfehler
Der Server konnte die Anfrage nicht fertig stellen.
Sollte dies erneut auftreten, senden Sie bitte die nachfolgenden technischen Einzelheiten an Ihren Server-Administrator.
Weitere Details können im Server-Protokoll gefunden werden.
Folgendes steht im Apache2 Error-LOG:
[Thu Mar 30 00:00:02.666679 2023] [ssl:warn] [pid 857] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Thu Mar 30 00:00:02.666846 2023] [mpm_prefork:notice] [pid 857] AH00163: Apache/2.4.41 (Ubuntu) OpenSSL/1.1.1f configured -- resuming normal operations
[Thu Mar 30 00:00:02.666853 2023] [core:notice] [pid 857] AH00094: Command line: '/usr/sbin/apache2'
[Thu Mar 30 20:20:01.827316 2023] [autoindex:error] [pid 190091] [client 192.168.6.16:34538] AH01276: Cannot serve directory /var/www/nextcloud/apps/dashboard/: No matching DirectoryIndex (index.php,index.html) found, and serv>
[Thu Mar 30 20:20:07.497431 2023] [autoindex:error] [pid 190080] [client 192.168.6.16:45452] AH01276: Cannot serve directory /var/www/nextcloud/apps/dashboard/: No matching DirectoryIndex (index.php,index.html) found, and serv>
[Thu Mar 30 20:20:09.104344 2023] [autoindex:error] [pid 190083] [client 192.168.6.16:45458] AH01276: Cannot serve directory /var/www/nextcloud/apps/dashboard/: No matching DirectoryIndex (index.php,index.html) found, and serv>
[Thu Mar 30 20:21:09.573471 2023] [mpm_prefork:notice] [pid 857] AH00169: caught SIGTERM, shutting down
[Thu Mar 30 21:24:39.066084 2023] [ssl:warn] [pid 814] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Thu Mar 30 21:24:39.316934 2023] [ssl:warn] [pid 856] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Thu Mar 30 21:24:39.325817 2023] [mpm_prefork:notice] [pid 856] AH00163: Apache/2.4.41 (Ubuntu) OpenSSL/1.1.1f configured -- resuming normal operations
[Thu Mar 30 21:24:39.325843 2023] [core:notice] [pid 856] AH00094: Command line: '/usr/sbin/apache2'
Client 192.168.6.16 = NGINX Proxy Server
System:
Distributor ID: Ubuntu
Description: Ubuntu 20.04.6 LTS
Release: 20.04
Codename: focal
Weis jemand wie ich das wieder hinbekomme?
