Nextcloud version (16.0.9.2):
server infos: https://office.familie.schlagheck.org/phpinfo.php
Issue: white page without login after upgrade
Is this the first time you’ve seen this error? (Y):
line 391937
{"reqId":"X105Ek7CicE1gYT58Nj9EgAAAA8","level":3,"time":"2020-09-12T21:09:38+00:00","remoteAddr":"93.104.86.88","user":"--","app":"no app in context","method":"GET","url":"\/index.php\/login","message":{"Exception":"InvalidArgumentException","Message":"Notifier Nutzungsbedingungen (id: terms_of_service) is not considered because it is using the old way to register.","Code":0,"Trace":[{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/apps\/terms_of_service\/lib\/AppInfo\/Application.php","line":131,"function":"registerNotifier","class":"OC\\Notification\\Manager","type":"->","args":[{"__class__":"Closure"},{"__class__":"Closure"}]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/apps\/terms_of_service\/lib\/AppInfo\/Application.php","line":49,"function":"registerNotifier","class":"OCA\\TermsOfService\\AppInfo\\Application","type":"->","args":[]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/apps\/terms_of_service\/appinfo\/app.php","line":25,"function":"register","class":"OCA\\TermsOfService\\AppInfo\\Application","type":"->","args":[]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/legacy\/app.php","line":265,"args":["\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/apps\/terms_of_service\/appinfo\/app.php"],"function":"require_once"},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/legacy\/app.php","line":155,"function":"requireAppFile","class":"OC_App","type":"::","args":[{"__class__":"OCA\\TermsOfService\\AppInfo\\Application"}]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/legacy\/app.php","line":128,"function":"loadApp","class":"OC_App","type":"::","args":["terms_of_service"]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/legacy\/util.php","line":196,"function":"loadApps","class":"OC_App","type":"::","args":[["filesystem"]]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/Files\/Filesystem.php","line":266,"function":"setupFS","class":"OC_Util","type":"::","args":[""]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/Server.php","line":291,"function":"getMountManager","class":"OC\\Files\\Filesystem","type":"::","args":[null]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":118,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/ServerContainer.php","line":120,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["RootFolder"]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/Server.php","line":313,"function":"query","class":"OC\\ServerContainer","type":"->","args":["RootFolder"]},{"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/Files\/Node\/LazyRoot.php","line":61,"function":"call_user_func","args":[{"__class__":"Closure"}]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/Files\/Node\/LazyRoot.php","line":141,"function":"__call","class":"OC\\Files\\Node\\LazyRoot","type":"->","args":["get",["appdata_ocragatkwel7\/theming\/images"]]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/Files\/AppData\/AppData.php","line":140,"function":"get","class":"OC\\Files\\Node\\LazyRoot","type":"->","args":["appdata_ocragatkwel7\/theming\/images"]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/apps\/theming\/lib\/ImageManager.php","line":106,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["images"]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/apps\/theming\/lib\/ThemingDefaults.php","line":222,"function":"getImage","class":"OCA\\Theming\\ImageManager","type":"->","args":["logo",true]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/public\/Defaults.php","line":187,"function":"getLogo","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[true]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/core\/templates\/layout.guest.php","line":42,"function":"getLogo","class":"OCP\\Defaults","type":"->","args":[]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/Template\/Base.php","line":178,"args":["\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/core\/templates\/layout.guest.php"],"function":"include"},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/Template\/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->","args":["\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/core\/templates\/layout.guest.php",null]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/legacy\/template.php","line":180,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/legacy\/template.php","line":211,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/Template\/Base.php","line":131,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/base.php","line":399,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/base.php","line":952,"function":"printUpgradePage","class":"OC","type":"::","args":[{"__class__":"OC\\SystemConfig"}]},{"file":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/index.php","line":42,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"\/www\/htdocs\/xxx\/office.familie.schlagheck.org\/lib\/private\/Notification\/Manager.php","Line":86,"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (Windows NT 10.0; rv:78.0) Gecko\/20100101 Firefox\/78.0","version":"16.0.9.2"}
line 391938
{"reqId":"X105Ek7CicE1gYT58Nj9EgAAAA8","level":3,"time":"2020-09-12T21:09:38+00:00","remoteAddr":"93.104.86.88","user":"--","app":"PHP","method":"GET","url":"\/index.php\/login","message":"Declaration of OCA\\GroupFolders\\Versions\\VersionsBackend::getVersionFile(OCP\\IUser $user, OCP\\Files\\FileInfo $sourceFile, int $revision): OCP\\Files\\File must be compatible with OCA\\Files_Versions\\Versions\\IVersionBackend::getVersionFile(OCP\\IUser $user, OCP\\Files\\FileInfo $sourceFile, $revision): OCP\\Files\\File at \/www\/htdocs\/xxx\/office.familie.schlagheck.org\/apps\/groupfolders\/lib\/Versions\/VersionsBackend.php#38","userAgent":"Mozilla\/5.0 (Windows NT 10.0; rv:78.0) Gecko\/20100101 Firefox\/78.0","version":"16.0.9.2"}
config.php
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'office.familie.schlagheck.org',
'datadirectory' => '/www/htdocs/xxx/office.familie.schlagheck.org/data',
'version' => '16.0.9.2',
'overwrite.cli.url' => 'http://office.familie.schlagheck.org',
'dbname' => 'xxx',
'dbhost' => 'localhost',
'dbtableprefix' => 'xxx',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'tempdirectory' => '/www/htdocs/xxx/office.familie.schlagheck.org/tmp/',
'mail_smtpmode' => 'sendmail',
'mail_sendmailmode' => 'pipe',
'mail_from_address' => 'xxxx',
'mail_domain' => 'xxx',
'ldapIgnoreNamingRules' => false,
'theme' => '',
'loglevel' => 0,
'updater.secret' => '$2y$xxx.o.j3Y9xxx5zQ/Exxxliv//qxxxhC',
'debug' => true,
(android client states nc in maintenance mode)
