Unit of Measurement Setting in Nextcloud Office
I wanted to ask whether Nextcloud Office includes an option to change the unit of measurement from inches to centimeters.
I came across this discussion, which mentions an “Advanced Settings” section. However, I was unable to find a specific Unit of Measurement option under the Files settings tab.
Has this feature been implemented yet? It has been over two years since the discussion, so I would expect a setting allowing unit conversion—especially if direct input in different units is not supported.
I appreciate any insights or updates on this. Thanks in advance for your response!
That’s because this thread is about the OnlyOffice document editor. Nextcloud Office uses Collabora Online.
As far as I know, there’s no such setting in Collabora. Instead, it’s tied to Nextcloud’s language settings. For example, if you set the language in your personal settings to English (British English), you’ll get centimeters in Nextcloud Office. Of course, this will also affect other units and the rest of Nextcloud, which may or may not be desired.
See also this thread: How to set the default length unit used in Collabora Online
Oh thanks. It did help me indeed change to cm. :grinning:
