Currently trying to upgrade from 26.0.1.1 using Docker compose file.
Seems like when trying to do the upgrade it thinks that newer versions are a downgrade. Also getting the issue with the post_max_size. I’m trying to find where this is set in the docker volume files for Nextcloud.
I’ve checked ini.php, .htaccess, and .user.ini.
Here is the logs file from docker compose logs
nextcloud-app-1 | Can't start Nextcloud because the version of the data (
nextcloud-app-1 | Warning: Invalid "post_max_size" setting. Invalid quantity "5.5G", interpreting as "5G" for backwards compatibility in Unknown on line 0
nextcloud-app-1 | 26.0.1.1) is higher than the docker image version (
nextcloud-app-1 | 26.0.3.2) and downgrading is not supported. Are you sure you have pulled the newest image version?
Any suggestions would be greatly appreciated.
