example
longer
example
here
Nextcloud version (eg, 21.0.1): 21.0.1
Operating System: | Linux 5.4.0-72-generic x86_64 |
CPU: | AMD EPYC 7302P 16-Core Processor (4 cores) |
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): Version: 7.4.3
Is this the first time you’ve seen this error? (Y/N):y
{“reqId”:“dMwkJrw3NST4AvHaKmm1”,“level”:3,“time”:“2021-04-29T15:45:02+00:00”,“remoteAddr”:"",“user”:"–",“app”:“core”,“method”:"",“url”:"–",“message”:{“Exception”:“TypeError”,“Message”:“Argument 2 passed to OCA\Circles\Db\CirclesRequest::getCircle() must be of the type string, null given, called in /data/nextcloud/apps/circles/lib/Service/CirclesService.php on line 277”,“Code”:0,“Trace”:[{“file”:"/data/nextcloud/apps/circles/lib/Service/CirclesService.php",“line”:277,“function”:“getCircle”,“class”:“OCA\Circles\Db\CirclesRequest”,“type”:"->"},{“file”:"/data/nextcloud/apps/circles/lib/Api/v1/Circles.php",“line”:265,“function”:“detailsCircle”,“class”:“OCA\Circles\Service\CirclesService”,“type”:"->"},{“file”:"/data/nextcloud/apps/deck/lib/Service/PermissionService.php",“line”:265,“function”:“detailsCircle”,“class”:“OCA\Circles\Api\v1\Circles”,“type”:"::"},{“file”:"/data/nextcloud/apps/deck/lib/Activity/ActivityManager.php",“line”:450,“function”:“findUsers”,“class”:“OCA\Deck\Service\PermissionService”,“type”:"->"},{“file”:"/data/nextcloud/apps/deck/lib/Activity/ActivityManager.php",“line”:265,“function”:“sendToUsers”,“class”:“OCA\Deck\Activity\ActivityManager”,“type”:"->"},{“file”:"/data/nextcloud/apps/deck/lib/Cron/CardDescriptionActivity.php",“line”:58,“function”:“triggerEvent”,“class”:“OCA\Deck\Activity\ActivityManager”,“type”:"->"},{“file”:"/data/nextcloud/lib/private/BackgroundJob/Job.php",“line”:52,“function”:“run”,“class”:“OCA\Deck\Cron\CardDescriptionActivity”,“type”:"->"},{“file”:"/data/nextcloud/cron.php",“line”:128,“function”:“execute”,“class”:“OC\BackgroundJob\Job”,“type”:"->"}],“File”:"/data/nextcloud/apps/circles/lib/Db/CirclesRequest.php",“Line”:192,“CustomMessage”:“Error while running background job (class: OCA\Deck\Cron\CardDescriptionActivity, arguments: )”},“userAgent”:"–",“version”:“21.0.1.1”,“id”:“608ad76888d27”}
