NextCloud 11 after upgrade
Ubuntu 16.04
SSL enabled
Strict https
redis cache
So I have two errors going on in my admin log page. Not sure what they are trying to tell me or how to fix them.
the first one is
Error while running background job (Doctrine\DBAL\Exception\SyntaxErrorException): An exception occurred while executing ‘DELETE FROM oc_activity_mq WHERE amq_timestamp <= ? AND amq_affecteduser IN ()’ with params [1482457945]: SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘)’ at line 1
OCA\Activity\BackgroundJob\EmailNotification ):
/var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php - line 128: Doctrine\DBAL\Driver\AbstractMySQLDriver->convertException('An exception oc...', Object(Doctrine\DBAL\Driver\PDOException))
/var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Statement.php - line 177: Doctrine\DBAL\DBALException driverExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Driver\PDOException), 'DELETE FROM `oc...', Array)
/var/www/nextcloud/apps/activity/lib/MailQueueHandler.php - line 334: Doctrine\DBAL\Statement->execute(Array)
/var/www/nextcloud/apps/activity/lib/BackgroundJob/EmailNotification.php - line 131: OCA\Activity\MailQueueHandler->deleteSentItems(Array, 1482457945)
/var/www/nextcloud/apps/activity/lib/BackgroundJob/EmailNotification.php - line 85: OCA\Activity\BackgroundJob\EmailNotification->runStep(25, 1482457945)
/var/www/nextcloud/lib/private/BackgroundJob/Job.php - line 53: OCA\Activity\BackgroundJob\EmailNotification->run(NULL)
/var/www/nextcloud/lib/private/BackgroundJob/TimedJob.php - line 54: OC\BackgroundJob\Job->execute(Object(OC\BackgroundJob\JobList), Object(OC\Log))
/var/www/nextcloud/cron.php - line 145: OC\BackgroundJob\TimedJob->execute(Object(OC\BackgroundJob\JobList), Object(OC\Log))
{main}
and the second one is:
Uncaught Error: Access to undeclared static property: OC\Files\Filesystem::$normalizedPathCache in /var/www/nextcloud/lib/private/Files/Filesystem.php:806 Stack trace: #0 /var/www/nextcloud/lib/private/Files/View.php(2018): OC\Files\Filesystem::normalizePath('/user/files/Pho...') #1 /var/www/nextcloud/lib/private/Files/View.php(1156): OC\Files\View->unlockFile('/Photos/Picture...', 1) #2 [internal function]: OC\Files\View->OC\Files\{closure}() #3 /var/www/nextcloud/3rdparty/icewind/streams/src/CallbackWrapper.php(109): call_user_func(Object(Closure)) #4 [internal function]: Icewind\Streams\CallbackWrapper->stream_close() #5 {main} thrown at /var/www/nextcloud/lib/private/Files/Filesystem.php#806
if anyone has any information on what these mean and how to fix them I would really appreciate it.
Thank you.
