Found out what was causing the error
Issue : CloudFlare
I use cloudflare to host my websites. Cloudflare doesn’t support port 3478, for which was causing the turnserver test to fail.
Issue : CloudFlare
You mean you were using the reverse proxy feature of Cloudflare, right?
I’m using Cloudflare too and i have disabled it long time ago because with that feature enabled syncing does not work properly. Or better i could not find out on how to setup it for Nextcloud.
Oh.
Ya you are right.
These are the ports when the proxy’s on
HTTP ports supported by Cloudflare:
80
8080
8880
2052
2082
2086
2095
HTTPS ports supported by Cloudflare:
443
2053
2083
2087
2096
8443
Let me check without them.
Problem is, when I turn off the proxy, the website doesn’t even show up. It just says the site couldn’t be reached
