TOTP works great so far for me. I was wondering though wether it is possible to scan the QR code with more than one device (e.g. Phone) at the same time and use, in my case, both Phones for Authenticating the same user account ??
That should be possible. The TOTP code is generated based on the QR code & current time (in 30sec intervals)
So if both phones have the same QR code they should both generate correct TOTP codes.
