I’m trying to upgrade nextcloud from 19.0.13.1 to 20.0.12. I’m running into an issue where I’m getting this error message:
root@nextcloud-nginx-9f99f5d75-grr6s:/var/www/html/nextcloud# sudo -u www-data bash -c 'php -f occ upgrade -vv'
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
2021-11-21T04:14:38+00:00 Setting log level to debug
2021-11-21T04:14:38+00:00 Repair step: Repair MySQL collation
2021-11-21T04:14:38+00:00 Repair info: All tables already have the correct collation -> nothing to do
2021-11-21T04:14:38+00:00 Repair step: Repair SQLite autoincrement
2021-11-21T04:14:38+00:00 Repair step: Copy data from accounts table when migrating from ownCloud
2021-11-21T04:14:38+00:00 Repair step: Drop account terms table when migrating from ownCloud
2021-11-21T04:14:38+00:00 Updating database schema
2021-11-21T04:14:39+00:00 Doctrine\DBAL\Exception\UniqueConstraintViolationException: An exception occurred while executing 'INSERT INTO `oc_storages_credentials` (`user`, `identifier`, `credentials`) VALUES(?, ?, ?)' with params ["some.user", "password::logincredentials\/credentials", "xxxyyy|xxxyyy|xxxyyy|x"]:
SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry 'some.user-password::logincredentials/credentials' for key 'stocred_ui'
2021-11-21T04:14:39+00:00 Update failed
2021-11-21T04:14:39+00:00 Maintenance mode is kept active
2021-11-21T04:14:39+00:00 Resetting log level
I’m not sure why I’m running into this, any idea?
Nextcloud version (eg, 20.0.5): 19.0.13.1
Operating system and version (eg, Ubuntu 20.04): bullseye/sid
Apache or nginx version (eg, Apache 2.4.25): nginx/1.18.0
PHP version (eg, 7.4): 7.4
- upgrade the nextcloud installation
- RUN: sudo -u www-data bash -c ‘php -f occ upgrade -vv’
- check the logs.
n/a (installation is broken.)
'instanceid' => 'xxxyyy',
'passwordsalt' => 'xxxyyy',
'secret' => 'xxxyyy',
0 => 'example.net',
'forwarded_for_headers' =>
0 => 'HTTP_X_FORWARDED',
1 => 'HTTP_FORWARDED_FOR',
'trusted_proxies' => '10.42.0.0/16',
'overwritecondaddr' => '^10\.42\.0\.1$',
'forcessl' => true,
'integrity.check.disabled' => true,
'overwrite.cli.url' => 'https://example.net',
'version' => '19.0.13.1',
'dbname' => 'nextcloud',
'dbhost' => 'mariadb-mariadb.databases',
'dbuser' => 'nextcloud',
'dbpassword' => 'xxxyyy',
'filesystem_cache_readonly' => true,
'cache_path' => '',
'objectstore' =>
'class' => 'OC\\Files\\ObjectStore\\S3',
'arguments' =>
'bucket' => 's3bucket',
'autocreate' => false,
'key' => 'xxxyyy',
'hostname' => 's3bucket',
'port' => 9000,
'use_ssl' => false,
'region' => 'optional',
'use_path_style' => true,
'redis' =>
'port' => 6379,
'host' => 'redis-ha.cache-service',
'database' => 510,
'theme' => '',
'loglevel' => 0,
