Besides that NC is telling me to update PHP, it also tells me that:
i have to run occ db:add-missing-columns
So i am trying to do that:
cd /var/www/nextcloud
sudo -u www-data php occ db:add-missing-columns
But than i get the error:
Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: couldn’t find driver in /var/www/nextcloud/lib/private/DB/Connection.php:67
You should know which database (SQLite3, MySQL/MariaDB, etc.) you’ve used to set-up Nextcloud. It might help to check the dbtype-parameter in the Nextcloud configuration file. Additionally the database should already have been configured for the php-web component. Maybe it’s only a copy job to get the right configuration file for the php-cli component. Keep in mind to install and use the correct module for the used php version
