I bought a preconfigured VM from techandme for ver 11.0.2. It is hardened. My site passes the security test from nextcloud with an A.
I am trying to update it with the web interface and it errors at checking for expected files.
“”""Initializing Current version is 11.0.2. Update to Nextcloud 11.0.3 available. (channel: “production”) Following file will be downloaded automatically: https://download.nextcloud.com/server/releases/nextcloud-11.0.3.zip **Retry update ** Check for expected files The following extra files have been found: results
I have looked all over the server can not find results anywhere.
I may have to change permissions on some directories to complete the upgrade.
Any ideas ?
john
I got the VMDK from techandme.com They has a complete package all setup with a wizard that configured Nextcloud completely including even setting up lets encrypt. They also have an update script build in to the server that did the upgrade to ver 12.0 and it worked completely. They harden the system with directory permissions and other settings that make the script from nextcloud work without a lot of tweaking.
John
