Hello, everyone.
Seeing that nobody answered in Spanish, I’ll give it a try in English.
I have just installed NextcloudPI, using a script an IT specialist posted. Otherwise it was absolutely IMPOSSIBle to make it work.
THe issue is that in the moment I try to set the nc-datadir outside the SD (which is only 16 GB), and the nc-database too, I get error messages, and everything stops working. The server, the Nextcloud instance, everything. I tries in at least 15 installations before, to change in the apache files -errors over errors… and so on, formatting the sd each time (removing Nextcloudpi cleanly is impossible for me. At least at this moment).
FInally, I found a solution. I managed to add as external storage SFTP the directory set on a hdd pluged into my raspberry pi (it’s a raspberry pi 4, 1gb Ram). It works, but the transcription rate is really slow, and I wish I could save the writing on the sd as much as possible.
Colud anyone guide/help me thorugh the process, even in the command line, step by step doing it without errors??? I am really tired of formatting the sd, adding all the other servers again and again?? Please, a good step by step tutorial, or link, or something that might make it work? Such a great program, nextcloudpi, and so many errors - please…
thanks in advance…
Ok. Understood.
For example: I followed this instructions: https://www.fororaspberry.es/viewtopic.php?f=6&t=12265&hilit=Manual+Nextcloud (I was able to install and make it work in a first instance the Nextcloud. But, when I tried to fix the errors, following step by step the instructions of this tutorial I got the apacher server broken - famous server error…, or an error related to the occ files/comand. So it was impossible for me to solve any of the errors - as a consequence I had to format the SD and follow the link I mention in the following paragraph, with the script.
Please take into account that I am not a programmer, and all I know of linux is based on troubleshooting I came across and tried to solve with the help of interent, forums and programmers that help us, the newbies in those forums. That is why everything is so complicated for me.
As about the errors I did not save any of them - but they were wether related to the server (SERVER ERROR) or to dependencies that were unable to be installed (for example all related with php7.4* impossible to install - mcrypt impossible (for me!) to install it.
The link I used is this: https://jartigag.xyz/nextcloudpi/ ( in this page copying the wget comand it installed the NextcloudPi - which for the moment works fine. I hope it lasts, because, just as I said, I grew tired of formating the sd - ja ja!!!).
So, having said that (sorry for not being able to tell you more about the errors - but these were the ones that most impacted me!!), please, any step by step solution/guidance to be able to move the datadir and database dir to the hdd without losing the NextcloudPi and avoiding errors???
Thanks in advance!!!
P.S: I looked at the docs, but honestly they raised more questions about how to do things I never learned. This is why I’ve been asking for this sort of help… step by step.
