Ubuntu Core 16 + nextcloud snap 1773 + https://github.com/nextcloud/twofactor_totp#readme
Once enabled, TOTP login attempt always fails. I can recover using a backup code.
Perhaps the “Authentication code [Verify]” will verify everything is working before enabling? The current release of this extension does not currently verify.
I can make this a new issue in github for the extension if someone else can please confirm if it is working in the current nextcloud snap?
Update 1: Instead of a self-signed SSL cert, I used a custom openssl generated key and CSR. cacert.org returned the CRT. I concatenated root+intermediate+CRT to chain.pem. The extension shouldn’t care though.
I am unable to find the logs specific to the TOTP extension:
root@snap1-vm10:/var/snap/nextcloud/1773/apache/logs# tail error_log
[Mon Jun 19 06:15:34.000249 2017] [proxy_fcgi:error] [pid 1914:tid 139839728174848] [client 172.17.2.2:38402] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jun 19 06:15:52.958147 2017] [proxy:error] [pid 1915:tid 139839471007488] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /tmp/sockets/php-fpm.sock (*) failed
[Mon Jun 19 06:15:52.958203 2017] [proxy_fcgi:error] [pid 1915:tid 139839471007488] [client 172.17.2.2:38406] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jun 19 06:16:02.229440 2017] [mpm_event:notice] [pid 1912:tid 139839823484800] AH00491: caught SIGTERM, shutting down
[Mon Jun 19 06:16:38.544778 2017] [mpm_event:notice] [pid 1846:tid 139757789570944] AH00489: Apache/2.4.25 (Unix) OpenSSL/1.0.2g configured -- resuming normal operations
[Mon Jun 19 06:16:38.552733 2017] [core:notice] [pid 1846:tid 139757789570944] AH00094: Command line: 'httpd -d /snap/nextcloud/1773 -D EnableHTTPS -D FOREGROUND'
[Mon Jun 19 06:16:38.545791 2017] [unixd:alert] [pid 1850:tid 139757789570944] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Mon Jun 19 06:16:38.546182 2017] [unixd:alert] [pid 1849:tid 139757789570944] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Mon Jun 19 06:16:38.546536 2017] [unixd:alert] [pid 1848:tid 139757789570944] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
[Mon Jun 19 06:16:49.566014 2017] [unixd:alert] [pid 1948:tid 139757789570944] AH02155: getpwuid: couldn't determine user name from uid 4294967295, you probably need to modify the User directive
root@snap1-vm10:/var/snap/nextcloud/1773/apache/logs# tail php_errors.log
#4 /snap/nextcloud/1773/htdocs/lib/private/DB/Connection.php(147): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /snap/nextcloud/1773/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__con in /snap/nextcloud/1773/htdocs/lib/private/DB/Connection.php on line 60
[19-Jun-2017 06:16:34 UTC] PHP Fatal error: Uncaught Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory in /snap/nextcloud/1773/htdocs/lib/private/DB/Connection.php:60
Stack trace:
#0 /snap/nextcloud/1773/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\DB\Connection->connect()
#1 /snap/nextcloud/1773/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /snap/nextcloud/1773/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /snap/nextcloud/1773/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(621): Doctrine\DBAL\Connection->getDatabasePlatform()
