Token is not valid: Token does not exist (webdav sync)
Nextcloud version : 25.0.1 from Docker official images
Operating system and version : Ubuntu server
I have configured several calendars on my NC instance for my user.
When Thunderbird/Davx5 sync calendars (and I suppose contacts information as well), in the NC server log, I find lots of lines including: “Token is not valid: Token does not exist: token does not exist” and CPU consumption gets higher (server and sometime my computer).
  1. Force syncing calendar from Thunderbird or DavX5
  2. Visualize NC log file
{"reqId":"65QmhvutWuYv5JxASFg9","level":0,"time":"2022-12-04T10:39:31+00:00","remoteAddr":"X.X.X.X","user":"--","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/calendars/my_user/app-generated--deck--board-1/","message":"Token is not valid: Token does not exist: token does not exist","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Thunderbird/102.4.2","version":"25.0.1.1","exception":{"Exception":"OC\\Authentication\\Exceptions\\InvalidTokenException","Message":"Token does not exist: token does not exist","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Authentication/Token/Manager.php","line":133,"function":"getToken","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/User/Session.php","line":523,"function":"getToken","class":"OC\\Authentication\\Token\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/User/Session.php","line":436,"function":"isTokenPassword","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","line":113,"function":"logClientIn","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php","line":103,"function":"validateUserPass","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","line":229,"function":"check","class":"Sabre\\DAV\\Auth\\Backend\\AbstractBasic","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","line":136,"function":"auth","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":180,"function":"check","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":135,"function":"check","class":"Sabre\\DAV\\Auth\\Plugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["beforeMethod:PROPFIND",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":360,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":171,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/lib/private/Authentication/Token/PublicKeyTokenProvider.php","Line":115,"Previous":{"Exception":"OCP\\AppFramework\\Db\\DoesNotExistException","Message":"token does not exist","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Authentication/Token/PublicKeyTokenProvider.php","line":111,"function":"getToken","class":"OC\\Authentication\\Token\\PublicKeyTokenMapper","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Authentication/Token/Manager.php","line":133,"function":"getToken","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/User/Session.php","line":523,"function":"getToken","class":"OC\\Authentication\\Token\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/User/Session.php","line":436,"function":"isTokenPassword","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","line":113,"function":"logClientIn","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php","line":103,"function":"validateUserPass","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","line":229,"function":"check","class":"Sabre\\DAV\\Auth\\Backend\\AbstractBasic","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","line":136,"function":"auth","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":180,"function":"check","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":135,"function":"check","class":"Sabre\\DAV\\Auth\\Plugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["beforeMethod:PROPFIND",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":360,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":171,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/lib/private/Authentication/Token/PublicKeyTokenMapper.php","Line":89},"message":"Token is not valid: Token does not exist: token does not exist","exception":{},"CustomMessage":"Token is not valid: Token does not exist: token does not exist"}}
  'forcessl' => true,
  'defaultapp' => 'dashboard',
  'knowledgebaseenabled' => true,
  'knowledgebaseurl' => 'http://api.apps.owncloud.com/v1',
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'instanceid' => 'id_number',
  'passwordsalt' => 'password_salt',
  'secret' => 'secret_number',
    0 => 'domain1',
    1 => 'domain2',
  'datadirectory' => '/mnt/data',
  'version' => '25.0.1.1',
  'overwrite.cli.url' => 'https://domain1',
  'dbname' => 'nextcloud',
  'dbhost' => 'nextcloud-db',
  'dbuser' => 'nextcloud',
  'dbpassword' => 'db_password',
  'mail_smtpdebug' => false,
  'mail_smtpmode' => 'smtp',
  'mail_smtphost' => 'smtp_host',
  'mail_smtpport' => '465',
  'mail_smtptimeout' => 10,
 'trashbin_retention_obligation' => 'auto, 7',
  'allow_user_to_change_display_name' => true,
  'updatechecker' => true,
  'mail_domain' => 'mail_domain',
  'mail_smtpsecure' => 'ssl',
  'mail_smtpauth' => 1,
  'mail_smtpname' => 'nextcloud@domain',
  'mail_smtppassword' => 'password',
  'default_phone_region' => 'FR',
  'app_install_overwrite' =>
    0 => 'gpxmotion',
    1 => 'piwik',
    2 => 'news',
    3 => 'appointments',
    4 => 'collectives',
    5 => 'cookbook',
    6 => 'drawio',
    7 => 'files_markdown',
    8 => 'libresign',
    9 => 'gpoddersync',
  'forwarded_for_headers' =>
    0 => 'HTTP_X_FORWARDED_FOR',
  'allow_local_remote_servers' => true,
  'loglevel' => 0,
  'theme' => '',
Thank you in advance !
I observe the same error on my instnace - however not in Thunderbird - only DavX5 on Android.
Hi, i’m facing the same issue after upgrading to php 7.4 and nextcloud 23.
update to php 8.1 and nextcloud 25.0.3 didn’t solved the problem.
actually i can’t upload any files :frowning:
I had the same problem. Check if the php-sodium package is installed.
Regards
Same issue in Version: Nextcloud Hub 3 (25.0.6)
And yes, sodium installed:
# php -m | grep sodium
sodium
Yes, Davx5 can not sync the contacts any more…
