"Token does not exist"-Error after Upgrade to 20.0.2
[/details]
Nextcloud version (eg, 18.0.2): 20.0.2
Operating system and version (eg, Ubuntu 20.04): Debian 10
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.38-3+deb10u4
PHP version (eg, 7.1): 2:7.3+69
Since the update to version 20.0.2 i see repeated errors while accessing nextcloud through davfs:
However, functionality seems not to be affected
Is this the first time you’ve seen this error? Occured with the upgrade to 20.0.2
Steps to replicate it: don’t know
{"reqId":"KbXPUces3V5Rq4wj8RVg","level":0,"time":"2020-12-01T08:32:01+00:00","remoteAddr":"10.64.65.1","user":"--","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/9E71B8A7-154D-4E55-B691-CE75DB3B8B23/example_dir/","message":"{\"Exception\":\"OC\\\\Authentication\\\\Exceptions\\\\InvalidTokenException\",\"Message\":\"Token does not exist\",\"Code\":0,\"Trace\":[{\"file\":\"/var/www/html/nextcloud/lib/private/Authentication/Token/Manager.php\",\"line\":147,\"function\":\"getToken\",\"class\":\"OC\\\\Authentication\\\\Token\\\\DefaultTokenProvider\",\"type\":\"->\",\"args\":[\"*** sensitive parameters replaced ***\"]},
    {\"file\":\"/var/www/html/nextcloud/lib/private/User/Session.php\",\"line\":532,\"function\":\"getToken\",\"class\":\"OC\\\\Authentication\\\\Token\\\\Manager\",\"type\":\"->\",\"args\":[\"*** sensitive parameters replaced ***\"]},
    {\"file\":\"/var/www/html/nextcloud/lib/private/User/Session.php\",\"line\":448,\"function\":\"isTokenPassword\",\"class\":\"OC\\\\User\\\\Session\",\"type\":\"->\",\"args\":[\"*** sensitive parameters replaced ***\"]},
    {\"file\":\"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php\",\"line\":131,\"function\":\"logClientIn\",\"class\":\"OC\\\\User\\\\Session\",\"type\":\"->\",\"args\":[\"*** sensitive parameters replaced ***\"]},
    {\"file\":\"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php\",\"line\":106,\"function\":\"validateUserPass\",\"class\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth\",\"type\":\"->\",\"args\":[\"*** sensitive parameters replaced ***\"]},
    {\"file\":\"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php\",\"line\":254,\"function\":\"check\",\"class\":\"Sabre\\\\DAV\\\\Auth\\\\Backend\\\\AbstractBasic\",\"type\":\"->\",\"args\":[{\"__class__\":\"Sabre\\\\HTTP\\\\Request\"},
    {\"__class__\":\"Sabre\\\\HTTP\\\\Response\"}]},
    {\"file\":\"/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php\",\"line\":156,\"function\":\"auth\",\"class\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth\",\"type\":\"->\",\"args\":[{\"__class__\":\"Sabre\\\\HTTP\\\\Request\"},
    {\"file\":\"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php\",\"line\":192,\"function\":\"check\",\"class\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Auth\",\"type\":\"->\",\"args\":[{\"__class__\":\"Sabre\\\\HTTP\\\\Request\"},
    {\"file\":\"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php\",\"line\":144,\"function\":\"check\",\"class\":\"Sabre\\\\DAV\\\\Auth\\\\Plugin\",\"type\":\"->\",\"args\":[{\"__class__\":\"Sabre\\\\HTTP\\\\Request\"},
    {\"file\":\"/var/www/html/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php\",\"line\":89,\"function\":\"beforeMethod\",\"class\":\"Sabre\\\\DAV\\\\Auth\\\\Plugin\",\"type\":\"->\",\"args\":[{\"__class__\":\"Sabre\\\\HTTP\\\\Request\"},
    {\"file\":\"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php\",\"line\":458,\"function\":\"emit\",\"class\":\"Sabre\\\\DAV\\\\Server\",\"type\":\"->\",\"args\":[\"beforeMethod:PROPFIND\",[{\"__class__\":\"Sabre\\\\HTTP\\\\Request\"},
    {\"__class__\":\"Sabre\\\\HTTP\\\\Response\"}]]},
    {\"file\":\"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php\",\"line\":251,\"function\":\"invokeMethod\",\"class\":\"Sabre\\\\DAV\\\\Server\",\"type\":\"->\",\"args\":[{\"__class__\":\"Sabre\\\\HTTP\\\\Request\"},
    {\"file\":\"/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php\",\"line\":319,\"function\":\"start\",\"class\":\"Sabre\\\\DAV\\\\Server\",\"type\":\"->\",\"args\":[]},
    {\"file\":\"/var/www/html/nextcloud/apps/dav/lib/Server.php\",\"line\":332,\"function\":\"exec\",\"class\":\"Sabre\\\\DAV\\\\Server\",\"type\":\"->\",\"args\":[]},
    {\"file\":\"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php\",\"line\":35,\"function\":\"exec\",\"class\":\"OCA\\\\DAV\\\\Server\",\"type\":\"->\",\"args\":[]},
    {\"file\":\"/var/www/html/nextcloud/remote.php\",\"line\":167,\"args\":[\"/var/www/html/nextcloud/apps/dav/appinfo/v2/remote.php\"],\"function\":\"require_once\"}],\"File\":\"/var/www/html/nextcloud/lib/private/Authentication/Token/DefaultTokenProvider.php\",\"Line\":160,\"Previous\":{\"Exception\":\"OCP\\\\AppFramework\\\\Db\\\\DoesNotExistException\",\"Message\":\"token does not exist\",\"Code\":0,\"Trace\":[{\"file\":\"/var/www/html/nextcloud/lib/private/Authentication/Token/DefaultTokenProvider.php\",\"line\":158,\"function\":\"getToken\",\"class\":\"OC\\\\Authentication\\\\Token\\\\DefaultTokenMapper\",\"type\":\"->\",\"args\":[\"*** sensitive parameters replaced ***\"]},
  'instanceid' => 'xxxx',
  'passwordsalt' => 'xxxxx',
  'secret' => 'xxxxxx',
    0 => 'servername',
    1 => '10.64.65.31',
  'datadirectory' => '/var/www/nextcloud_data',
  'dbtype' => 'pgsql',
  'version' => '20.0.2.2',
  'overwrite.cli.url' => 'https://servername',
  'dbname' => 'nextclouddb',
  'dbhost' => 'localhost:5432',
  'dbuser' => 'nextcloud',
  'dbpassword' => 'xxxxxxxxxxxxxxx',
  'ldapIgnoreNamingRules' => false,
  'loglevel' => 0,
  'log_type' => 'syslog',
  'theme' => '',
  'app_install_overwrite' =>
    0 => 'calendar',
10.64.65.1 - techuser.edicloud [01/Dec/2020:08:32:01 +0100] "PROPFIND /remote.php/dav/files/9E71B8A7-154D-4E55-B691-CE75DB3B8B23/example_dir/ HTTP/1.1" 207 34585 "-" "davfs2/1.5.5 neon/0.30.2"
Same problem and same log output on my side on a newly built Nextcloud (docker) instance.
Hi @Kinimod! Since in my case functionality is affected (currently I am not able to sync my calendar and addressbooks and so all this data is missing on my phone), I am thinking about to downgrade my installation. Can you tell me from which version you were coming (I assume that you did not have this behaviour there)? Thank you very much in advance!
I have the same probelm with caldav. Full log error below: Anyone got an idea for how this can be fixed? Using 2fa.
{“reqId”:“Fh6nleh6dkc3wVs9B0zj”,“level”:0,“time”:“2021-01-19T07:25:45+00:00”,“remoteAddr”:“174.59.116.3”,“user”:"–",“app”:“no app in context”,“method”:“PROPFIND”,“url”:"/remote.php/dav/calendars/peter/work/",“message”:"{“Exception”:“OC\\Authentication\\Exceptions\\InvalidTokenException”,“Message”:“Token does not exist”,“Code”:0,“Trace”:[{“file”:"/var/www/nextcloud/lib/private/Authentication/Token/Manager.php",“line”:147,“function”:“getToken”,“class”:“OC\\Authentication\\Token\\DefaultTokenProvider”,“type”:"->",“args”:["*** sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/lib/private/User/Session.php",“line”:532,“function”:“getToken”,“class”:“OC\\Authentication\\Token\\Manager”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/lib/private/User/Session.php",“line”:448,“function”:“isTokenPassword”,“class”:“OC\\User\\Session”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php",“line”:131,“function”:“logClientIn”,“class”:“OC\\User\\Session”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php",“line”:106,“function”:“validateUserPass”,“class”:“OCA\\DAV\\Connector\\Sabre\\Auth”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php",“line”:254,“function”:“check”,“class”:“Sabre\\DAV\\Auth\\Backend\\AbstractBasic”,“type”:"->"},{“file”:"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php",“line”:156,“function”:“auth”,“class”:“OCA\\DAV\\Connector\\Sabre\\Auth”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php",“line”:192,“function”:“check”,“class”:“OCA\\DAV\\Connector\\Sabre\\Auth”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php",“line”:144,“function”:“check”,“class”:“Sabre\\DAV\\Auth\\Plugin”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php",“line”:89,“function”:“beforeMethod”,“class”:“Sabre\\DAV\\Auth\\Plugin”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:458,“function”:“emit”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:251,“function”:“invokeMethod”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:319,“function”:“start”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/apps/dav/lib/Server.php",“line”:332,“function”:“exec”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php",“line”:35,“function”:“exec”,“class”:“OCA\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/remote.php",“line”:167,“args”:["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],“function”:“require_once”}],“File”:"/var/www/nextcloud/lib/private/Authentication/Token/DefaultTokenProvider.php",“Line”:160,“Previous”:{“Exception”:“OCP\\AppFramework\\Db\\DoesNotExistException”,“Message”:“token does not exist”,“Code”:0,“Trace”:[{“file”:"/var/www/nextcloud/lib/private/Authentication/Token/DefaultTokenProvider.php",“line”:158,“function”:“getToken”,“class”:“OC\\Authentication\\Token\\DefaultTokenMapper”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/lib/private/Authentication/Token/Manager.php",“line”:147,“function”:“getToken”,“class”:“OC\\Authentication\\Token\\DefaultTokenProvider”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/lib/private/User/Session.php",“line”:532,“function”:“getToken”,“class”:“OC\\Authentication\\Token\\Manager”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/lib/private/User/Session.php",“line”:448,“function”:“isTokenPassword”,“class”:“OC\\User\\Session”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php",“line”:131,“function”:“logClientIn”,“class”:“OC\\User\\Session”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php",“line”:106,“function”:“validateUserPass”,“class”:“OCA\\DAV\\Connector\\Sabre\\Auth”,“type”:"->",“args”:[" sensitive parameters replaced "]},{“file”:"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php",“line”:254,“function”:“check”,“class”:“Sabre\\DAV\\Auth\\Backend\\AbstractBasic”,“type”:"->"},{“file”:"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php",“line”:156,“function”:“auth”,“class”:“OCA\\DAV\\Connector\\Sabre\\Auth”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php",“line”:192,“function”:“check”,“class”:“OCA\\DAV\\Connector\\Sabre\\Auth”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php",“line”:144,“function”:“check”,“class”:“Sabre\\DAV\\Auth\\Plugin”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php",“line”:89,“function”:“beforeMethod”,“class”:“Sabre\\DAV\\Auth\\Plugin”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:458,“function”:“emit”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:251,“function”:“invokeMethod”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:319,“function”:“start”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/apps/dav/lib/Server.php",“line”:332,“function”:“exec”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php",“line”:35,“function”:“exec”,“class”:“OCA\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/remote.php",“line”:167,“args”:["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],“function”:“require_once”}],“File”:"/var/www/nextcloud/lib/private/Authentication/Token/DefaultTokenMapper.php",“Line”:91},“CustomMessage”:“Token is not valid: Token does not exist”}",“userAgent”:“Mozilla/5.0 (X11; Linux x86_64; rv:68.0) Gecko/20100101 Thunderbird/68.10.0 Lightning/68.9.0”,“version”:“20.0.5.2”}
Jan 19 09:25:45 web06 Nextcloud[50335]: {“reqId”:“Fh6nleh6dkc3wVs9B0zj”,“level”:0,“time”:“2021-01-19T07:25:45+00:00”,“remoteAddr”:“172.69.114.7”,“user”:"–",“app”:“webdav”,“method”:“PROPFIND”,“url”:"/remote.php/dav/calendars/mark/work/",“message”:"{“Exception”:“OCA\\DAV\\Connector\\Sabre\\Exception\\PasswordLoginForbidden”,“Message”:"",“Code”:0,“Trace”:[{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php",“line”:106,“function”:“validateUserPass”,“class”:“OCA\\DAV\\Connector\\Sabre\\Auth”,“type”:"->",“args”:["
sensitive parameters replaced ***"]},{“file”:"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php",“line”:254,“function”:“check”,“class”:“Sabre\\DAV\\Auth\\Backend\\AbstractBasic”,“type”:"->"},{“file”:"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php",“line”:156,“function”:“auth”,“class”:“OCA\\DAV\\Connector\\Sabre\\Auth”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php",“line”:192,“function”:“check”,“class”:“OCA\\DAV\\Connector\\Sabre\\Auth”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php",“line”:144,“function”:“check”,“class”:“Sabre\\DAV\\Auth\\Plugin”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php",“line”:89,“function”:“beforeMethod”,“class”:“Sabre\\DAV\\Auth\\Plugin”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:458,“function”:“emit”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:251,“function”:“invokeMethod”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php",“line”:319,“function”:“start”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/apps/dav/lib/Server.php",“line”:332,“function”:“exec”,“class”:“Sabre\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php",“line”:35,“function”:“exec”,“class”:“OCA\\DAV\\Server”,“type”:"->"},{“file”:"/var/www/nextcloud/remote.php",“line”:167,“args”:["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],“function”:“require_once”}],“File”:"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php",“Line”:142,“CustomMessage”:"–"}",“userAgent”:“Mozilla/5.0 (X11; Linux x86_64; rv:68.0) Gecko/20100101 Thunderbird/68.10.0 Lightning/68.9.0”,“version”:“20.0.5.2”}
Same here on current 20.0.5. Please provide assistance.
Same problem here. Can not upload files using dav.
I have the same problem and tried already much possible solutions. A bugreport is also currently open from my side for the problem but no one answered since a week. Dont know what I can do.
I can successfully login in browser but not with devices / apps etc.
What’s the URL to your bug report, @xwarman ?
I am experiencing similar issues with two different Nextcloud instances (version 21.0.0 and 20.0.8), where users using app password and two-factor authentication (with notifications) on iOS are being disconnected and has to re-enter the app password to log back in. The inability to log in happens after 24h.
Server log when the user is disconnected and prompted to log in:
Debug    no app in context  OC\Authentication\Exceptions\InvalidTokenException: Token does not exist at .../Authentication/Token/DefaultTokenProvider.php line 160                      2021-10-10T18:03:42+00:00
                               0. lib/private/Authentication/Token/Manager.php line 147
                                  OC\Authentication\Token\DefaultTokenProvider->getToken("*** sensitive parameters replaced ***")
                               1. lib/private/User/Session.php line 532
                                  OC\Authentication\Token\Manager->getToken("*** sensitive parameters replaced ***")
                               2. lib/private/User/Session.php line 448
                                  OC\User\Session->isTokenPassword("*** sensitive parameters replaced ***")
                               3. apps/dav/lib/Connector/Sabre/Auth.php line 131
                                  OC\User\Session->logClientIn("*** sensitive parameters replaced ***")
                               4. 3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php line 103
                                  OCA\DAV\Connector\Sabre\Auth->validateUserPass("*** sensitive parameters replaced ***")
                               5. apps/dav/lib/Connector/Sabre/Auth.php line 254
                                  Sabre\DAV\Auth\Backend\AbstractBasic->check(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
                               6. apps/dav/lib/Connector/Sabre/Auth.php line 156
                                  OCA\DAV\Connector\Sabre\Auth->auth(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
                               7. 3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php line 182
                                  OCA\DAV\Connector\Sabre\Auth->check(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
                               8. 3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php line 137
                                  Sabre\DAV\Auth\Plugin->check(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
                               9. 3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
                                  Sabre\DAV\Auth\Plugin->beforeMethod(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
                              10. 3rdparty/sabre/dav/lib/DAV/Server.php line 456
                                  Sabre\DAV\Server->emit("beforeMethod:PUT", [Sabre\HTTP\Request {},Sabre\HTTP\Response {}])
                              11. 3rdparty/sabre/dav/lib/DAV/Server.php line 253
                                  Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
                              12. 3rdparty/sabre/dav/lib/DAV/Server.php line 321
                                  Sabre\DAV\Server->start(
                              13. apps/dav/appinfo/v1/webdav.php line 84
                                  Sabre\DAV\Server->exec(
                              14. remote.php line 167
                                  require_once("\/var\/www\/nextcloud\/apps\/dav\/appinfo\/v1\/webdav.php")
                              Caused by OCP\AppFramework\Db\DoesNotExistException: token does not exist at .../private/Authentication/Token/DefaultTokenMapper.php line 94
                               0. lib/private/Authentication/Token/DefaultTokenProvider.php line 158
                                  OC\Authentication\Token\DefaultTokenMapper->getToken("*** sensitive parameters replaced ***")
                               1. lib/private/Authentication/Token/Manager.php line 147
                               2. lib/private/User/Session.php line 532
                               3. lib/private/User/Session.php line 448
                               4. apps/dav/lib/Connector/Sabre/Auth.php line 131
                               5. 3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php line 103
                               6. apps/dav/lib/Connector/Sabre/Auth.php line 254
                               7. apps/dav/lib/Connector/Sabre/Auth.php line 156
                               8. 3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php line 182
                               9. 3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php line 137
                              10. 3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
                              11. 3rdparty/sabre/dav/lib/DAV/Server.php line 456
                              12. 3rdparty/sabre/dav/lib/DAV/Server.php line 253
                              13. 3rdparty/sabre/dav/lib/DAV/Server.php line 321
                              14. apps/dav/appinfo/v1/webdav.php line 84
                              15. remote.php line 167
  Debug    files_sharing      /appinfo/app.php is deprecated, use \OCP\AppFramework\Bootstrap\IBootstrap on the application class instead.                                                2021-10-10T18:03:42+00:00
  Debug    files_external     /appinfo/app.php is deprecated, use \OCP\AppFramework\Bootstrap\IBootstrap on the application class instead.                                                2021-10-10T18:03:42+00:00
  Debug    no app in context  OC\Authentication\Exceptions\InvalidTokenException: Token does not exist at .../Authentication/Token/DefaultTokenProvider.php line 160                      2021-10-10T18:03:43+00:00
Logs are much more verbose but I am not allowed to post more.
Hi there. I have the same error with 22.2.3 version.
Did you find a solution?
Thanks
Here my logs :
PHP message: {
	"reqId": "8bNB52BRSVBnXZRc6FOi",
	"level": 0,
	"time": "2022-06-16T21:22:06+00:00",
	"remoteAddr": "172.18.0.1",
	"user": "--",
	"app": "files_sharing",
	"method": "PROPFIND",
	"url": "/remote.php/dav/principals/users/xxxxxxxxxxx/",
	"message": "/appinfo/app.php is deprecated, use \\OCP\\AppFramework\\Bootstrap\\IBootstrap on the application class instead.",
	"userAgent": "OpenSync/1.5.0.3-ose (2017/04/18; dav4android; okhttp3) Android/11",
	"version": "22.2.3.0"
PHP message: {
	"level": 0,
	"time": "2022-06-16T21:22:08+00:00",
	"user": "--",
	"app": "no app in context",
	"message": "Token is not valid: Token does not exist",
	"version": "22.2.3.0",
	"exception": {
		"Exception": "OC\\Authentication\\Exceptions\\InvalidTokenException",
		"Message": "Token does not exist",
		"Code": 0,
		"Trace": [{
			"file": "/var/www/html/lib/private/Authentication/Token/Manager.php",
			"line": 146,
			"function": "getToken",
			"class": "OC\\Authentication\\Token\\DefaultTokenProvider",
			"type": "->",
			"args": ["*** sensitive parameters replaced ***"]
			"file": "/var/www/html/lib/private/User/Session.php",
			"line": 531,
			"class": "OC\\Authentication\\Token\\Manager",
			"type": "->",
			"line": 447,
			"function": "isTokenPassword",
			"class": "OC\\User\\Session",
			"type": "->",
			"file": "/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php",
			"line": 129,
			"function": "logClientIn",
			"type": "->",
			"file": "/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php",
			"line": 103,
			"function": "validateUserPass",
			"class": "OCA\\DAV\\Connector\\Sabre\\Auth",
			"type": "->",
			"line": 252,
			"function": "check",
			"class": "Sabre\\DAV\\Auth\\Backend\\AbstractBasic",
			"type": "->",
			"args": [{
				"__class__": "Sabre\\HTTP\\Request"
				"__class__": "Sabre\\HTTP\\Response"
			"line": 154,
			"function": "auth",
			"type": "->",
			"args": [{
			"file": "/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php",
			"line": 182,
			"type": "->",
			"args": [{
			"line": 137,
			"class": "Sabre\\DAV\\Auth\\Plugin",
			"type": "->",
			"args": [{
			"file": "/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php",
			"line": 89,
			"function": "beforeMethod",
			"type": "->",
			"args": [{
			"file": "/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php",
			"line": 456,
			"function": "emit",
			"class": "Sabre\\DAV\\Server",
			"type": "->",
			"args": ["beforeMethod:PROPFIND", [{
			"line": 253,
			"function": "invokeMethod",
			"type": "->",
			"args": [{
			"line": 321,
			"function": "start",
			"type": "->",
			"args": []
			"file": "/var/www/html/apps/dav/lib/Server.php",
			"line": 333,
			"function": "exec",
			"type": "->",
			"args": []
			"file": "/var/www/html/apps/dav/appinfo/v2/remote.php",
			"line": 35,
			"function": "exec",
			"class": "OCA\\DAV\\Server",
			"type": "->",
			"args": []
			"file": "/var/www/html/remote.php",
			"line": 166,
			"args": ["/var/www/html/apps/dav/appinfo/v2/remote.php"],
			"function": "require_once"
		"File": "/var/www/html/lib/private/Authentication/Token/DefaultTokenProvider.php",
		"Line": 159,
		"Previous": {
			"Exception": "OCP\\AppFramework\\Db\\DoesNotExistException",
			"Message": "token does not exist",
			"Code": 0,
			"Trace": [{
				"file": "/var/www/html/lib/private/Authentication/Token/DefaultTokenProvider.php",
				"line": 157,
				"class": "OC\\Authentication\\Token\\DefaultTokenMapper",
				"type": "->",
				"line": 146,
				"type": "->",
				"line": 531,
				"type": "->",
				"line": 447,
				"type": "->",
				"line": 129,
				"type": "->",
				"line": 103,
				"type": "->",
				"line": 252,
				"type": "->",
				"args": [{
				"line": 154,
				"function": "auth",
				"type": "->",
				"args": [{
				"line": 182,
				"type": "->",
				"args": [{
				"line": 137,
				"type": "->",
				"args": [{
				"line": 89,
				"type": "->",
				"args": [{
				"line": 456,
				"function": "emit",
				"type": "->",
				"line": 253,
				"type": "->",
				"args": [{
				"line": 321,
				"type": "->",
				"args": []
				"line": 333,
				"function": "exec",
				"type": "->",
				"args": []
				"line": 35,
				"function": "exec",
				"type": "->",
				"args": []
				"line": 166,
			"File": "/var/www/html/lib/private/Authentication/Token/DefaultTokenMapper.php",
			"Line": 93
		"CustomMessage": "Token is not valid: Token does not exist"
