example
longer
example
here
Nextcloud version: 15.0
Operating system and version: OpenBSD 6.4
Apache or nginx version: nginx 1.14.1
PHP version: 7.2
I finished the installation. Just after the first connexion as admin, i’ve the notice, in french “Ce dossier n’est pas disponible. Consultez les logs ou contactez votre administrateur”.
If i attempt to go by the menu at ‘Settings > User’, the server reply with this error:
Erreur interne du serveur
Le serveur est incapable d’exécuter votre requête.
Si cela se reproduit, veuillez envoyer les détails techniques ci-dessous à l’administrateur du serveur.
Le fichier journal du serveur peut fournir plus de renseignements.
Renseignements techniques
- Adresse distante : 88.136.16.221
- ID de la demande : LER0kC3g3XEtfWrHICr1
Is this the first time you’ve seen this error?: Yes
- Complete the install, with couple id/pass for admin, and values for DB and DB User
- At the first connexion
I can’t see this menu!
'instanceid' => '***',
'passwordsalt' => '***',
'secret' => '***',
0 => 'doc.stephane-huc.net',
'datadirectory' => '',
'version' => '15.0.0.10',
'overwrite.cli.url' => 'https://doc.stephane-huc.net',
'dbname' => '***',
'dbhost' => 'localhost',
'dbuser' => '***',
'dbpassword' => '***',
88.136.16.221 - - [11/Dec/2018:15:51:14 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0" 200 74 "-" "Mozilla/5.0 (X11; OpenBSD amd64; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Iridium/2018.5 Safari/537.36 Chrome/67.0.3396.40"
88.136.16.221 - - [11/Dec/2018:15:51:44 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0" 200 74 "-" "Mozilla/5.0 (X11; OpenBSD amd64; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Iridium/2018.5 Safari/537.36 Chrome/67.0.3396.40"
88.136.16.221 - - [11/Dec/2018:15:52:14 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0" 200 74 "-" "Mozilla/5.0 (X11; OpenBSD amd64; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Iridium/2018.5 Safari/537.36 Chrome/67.0.3396.40"
88.136.16.221 - - [11/Dec/2018:15:52:44 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0" 200 74 "-" "Mozilla/5.0 (X11; OpenBSD amd64; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Iridium/2018.5 Safari/537.36 Chrome/67.0.3396.40"
88.136.16.221 - - [11/Dec/2018:15:53:14 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0" 200 74 "-" "Mozilla/5.0 (X11; OpenBSD amd64; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Iridium/2018.5 Safari/537.36 Chrome/67.0.3396.40"
88.136.16.221 - - [11/Dec/2018:15:53:44 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0" 200 74 "-" "Mozilla/5.0 (X11; OpenBSD amd64; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Iridium/2018.5 Safari/537.36 Chrome/67.0.3396.40"
88.136.16.221 - - [11/Dec/2018:15:54:14 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0" 200 74 "-" "Mozilla/5.0 (X11; OpenBSD amd64; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Iridium/2018.5 Safari/537.36 Chrome/67.0.3396.40"
88.136.16.221 - - [11/Dec/2018:15:54:44 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0" 200 74 "-" "Mozilla/5.0 (X11; OpenBSD amd64; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Iridium/2018.5 Safari/537.36 Chrome/67.0.3396.40"
