Das Problem ist dass die Oberfläche ohne css code geladen wird.
Normal ist das ganz normale nextcloud Standard design eingestellt
Ich bekomme auch trotz Konfigurationen die Fehlermeldungen alle nicht weg:
im Menü sieht man auch das fehlerhafte design.
Ich kann auch Keinerlei Design Einstellungen vornehmen es sieht immer gleich aus
Das währen meine ganzen configs:
nginx.conf
GNU nano 6.2 /etc/nginx/nginx.conf
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/*.conf;
events {
worker_connections 1024; # Increase worker connections for better concurrency
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on; # Enable to reduce latency
types_hash_max_size 2048;
client_max_body_size 50G;
proxy_read_timeout 7200s;
proxy_connect_timeout 7200s;
proxy_send_timeout 7200s;
send_timeout 7200s;
keepalive_timeout 65s;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# SSL Settings
ssl_protocols TLSv1.2 TLSv1.3; # Remove deprecated protocols (TLSv1, TLSv1.1)
ssl_prefer_server_ciphers on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
gzip_vary on;
gzip_proxied any;
gzip_comp_level 6;
gzip_buffers 16 8k;
gzip_http_version 1.1;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
nextcloud.conf
GNU nano 6.2 /etc/nginx/sites-available/nextcloud
upstream php-handler {
server unix:/var/run/php/php8.2-fpm.sock;
server {
listen 80;
listen [::]:80;
server_name 192.168.2.101 cloud.domain.at www.cloud.domain.at;
root /var/www/nextcloud;
index index.php index.html;
fastcgi_buffers 64 4K;
send_timeout 7200s;
add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
add_header X-Frame-Options "SAMEORIGIN";
proxy_set_header Host $host;
include mime.types;
types {
application/javascript mjs;
# Verhindere doppelte /index.php Anhängungen
location / {
try_files $uri $uri/ /index.php?$query_string;
# Serve static files (CSS, JS, images)
location ~ \.(?:css|js|mjs|svg|gif|ico|jpg|png|webp|wasm|tflite|map|ogg|flac)$ {
add_header Cache-Control "public, max-age=15778463";
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "noindex, nofollow" always;
add_header X-XSS-Protection "1; mode=block" always;
access_log off;
# Schriftarten und Icons Caching
location ~* \.(?:ttf|woff|woff2|ico|jpg|jpeg|png|gif|svg)$ {
expires 7d;
access_log off;
# PHP-Dateien verarbeiten
location ~ \.php(?:$|/) {
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
# Verhindere Zugriff auf sensible Verzeichnisse
location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/) {
return 404;
return 404;
# robots.txt
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
# WebDAV (remote.php)
location ~ ^/(remote\.php|public\.php|dav|\.well-known|webdav) {
# Regeln für OCS-Provider
location ^~ /ocs-provider/ {
location ^~ /ocm-provider/ {
# .well-known URLs für WebDAV und Let's Encrypt
location ^~ /.well-known {
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }
location /.well-known/acme-challenge { try_files $uri $uri/ =404; }
location /.well-known/pki-validation { try_files $uri $uri/ =404; }
config.php
GNU nano 6.2 /var/www/nextcloud/config/config.php
'instanceid' => 'xxxxxxxxxxxxxxxxx',
'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxx',
'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
0 => '192.168.2.101',
1 => 'cloud.domain.at',
2 => 'www.cloud.domain.at',
'trusted_proxies' =>
0 => '192.168.2.100',
'overwrite.cli.url' => 'https://cloud.domain.at',
'datadirectory' => '/TabelanderCloud/data',
'version' => '29.0.7.1',
'dbname' => 'xxxxxxxx',
'dbhost' => 'xxxxxxxx',
'dbuser' => 'xxxxxxxxxx',
'dbpassword' => 'xxxxxxxxxxx',
'tempdirectory' => '/TabelanderCloud/data/temp',
'redis' =>
'port' => 0,
'timeout' => 0.0,
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'noreply',
'mail_domain' => 'domain.at',
'mail_smtpport' => '465',
'mail_smtphost' => 'ssl0.net',
'default_phone_region' => 'AT',
'default_language' => 'de',
'default_locale' => 'de_AT',
'default_timezone' => 'Europe/Vienna',
'mail_smtpauth' => 1,
'mail_smtpname' => 'noreply@domain.at',
'mail_smtppassword' => 'xxxxxxxxxxxxxxxxx',
'memories.exiftool' => '/var/www/nextcloud/apps/memories/bin-ext/exiftool-amd64-glibc',
'memories.vod.path' => '/var/www/nextcloud/apps/memories/bin-ext/go-vod-amd64',
'backgroundjobs_mode' => 'cron',
'maintenance_window_start' => '00:00',
'maintenance_window_end' => '05:00',
'app_install_overwrite' =>
0 => 'facerecognition',
1 => 'libresign',
2 => 'llm',
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\PNG',
1 => 'OC\\Preview\\JPEG',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\BMP',
4 => 'OC\\Preview\\XBitmap',
5 => 'OC\\Preview\\Movie',
6 => 'OC\\Preview\\PDF',
7 => 'OC\\Preview\\MP3',
8 => 'OC\\Preview\\TXT',
9 => 'OC\\Preview\\MarkDown',
10 => 'OC\\Preview\\Image',
11 => 'OC\\Preview\\HEIC',
12 => 'OC\\Preview\\TIFF',
'memories.vod.disable' => false,
'preview_max_memory' => 2048,
'preview_max_filesize_image' => 400,
'memories.vod.ffmpeg' => '/usr/local/bin/ffmpeg',
'memories.vod.ffprobe' => '/usr/local/bin/ffprobe',
'preview_max_x' => 2048,
'preview_max_y' => 2048,
'loglevel' => 2,
'defaultapp' => '',
'remember_login_cookie_lifetime' => 1296000,
'session_lifetime' => 1800,
'session_keepalive' => false,
'auto_logout' => true,
'memories.gis_type' => 1,
'theme' => '',
'memories.vod.nvenc' => true,
'memories.db.triggers.fcu' => true,
'enforce_theme' => '',
'mail_smtpsecure' => 'ssl',
'debug' => true,
Ich hoffe das ist genau genug
LG
