Nextcloud version 13.0.1
Operating system and version Debian 9.4
Apache or nginx version Apache/2.4.25 (Debian)
PHP version 7.0.27-0+deb9u1
Database version mariadb Ver 15.1 Distrib 10.1.26-MariaDB
Unable to login to Nextcloud web interface via laptop but I can from my desktop PC. The login button does not respond.
Is this the first time you’ve seen this error? Yes.
Working PC
Not working laptop
Steps taken
- Cleared cache on laptop browser
- Cleared hidden .mozilla cache
- Tried different browsers
- Reformatted laptop (same result)
- Connected the laptop to the network via wi-fi, wired ethernet and tried both over a VPN and not over a VPN.
Desktop and laptop OS in Mint 18.3
Main browser used is Firefox 59.0.2 which is the same on both devices.
I have resolved the issues in the logs below. No new error logged since 12:39 today
"reqId":"i2UPSwHkjJ08DdeciaHd","level":3,"time":"2018-04-15T11:39:17+00:00","remoteAddr":"192.168.0.25","user":"user@domain.com","app":"PHP","method":"GET","url":"\/index.php\/login\/challenge\/totp?redirect_url=\/index.php\/settings\/user\/security","message":"file_get_contents(\/mnt\/FreeNAS\/nextcloud\/data\/appdata_ocamqr445cu4\/js\/core\/merged-template-prepend.js.deps): failed to open stream: No such file or directory at \/var\/www\/html\/nextcloud\/lib\/private\/Files\/Storage\/Local.php#214","userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:59.0) Gecko\/20100101 Firefox\/59.0","version":"13.0.1.1"}
{"reqId":"i2UPSwHkjJ08DdeciaHd","level":3,"time":"2018-04-15T11:39:17+00:00","remoteAddr":"192.168.0.25","user":"user@domain.com","app":"PHP","method":"GET","url":"\/index.php\/login\/challenge\/totp?redirect_url=\/index.php\/settings\/user\/security","message":"stat(): stat failed for \/mnt\/FreeNAS\/nextcloud\/data\/appdata_ocamqr445cu4\/js\/core\/merged-template-prepend.js.deps at \/var\/www\/html\/nextcloud\/lib\/private\/Files\/Storage\/Local.php#140","userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:59.0) Gecko\/20100101 Firefox\/59.0","version":"13.0.1.1"}
{"reqId":"i2UPSwHkjJ08DdeciaHd","level":3,"time":"2018-04-15T11:39:17+00:00","remoteAddr":"192.168.0.25","user":"user@domain.com","app":"PHP","method":"GET","url":"\/index.php\/login\/challenge\/totp?redirect_url=\/index.php\/settings\/user\/security","message":"stat(): stat failed for \/mnt\/FreeNAS\/nextcloud\/data\/appdata_ocamqr445cu4\/js\/core at \/var\/www\/html\/nextcloud\/lib\/private\/Files\/Storage\/Local.php#140","userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:59.0) Gecko\/20100101 Firefox\/59.0","version":"13.0.1.1"}
{"reqId":"i2UPSwHkjJ08DdeciaHd","level":3,"time":"2018-04-15T11:39:18+00:00","remoteAddr":"192.168.0.25","user":"user@domain.com","app":"PHP","method":"GET","url":"\/index.php\/login\/challenge\/totp?redirect_url=\/index.php\/settings\/user\/security","message":"stat(): stat failed for \/mnt\/FreeNAS\/nextcloud\/data\/appdata_ocamqr445cu4\/js at \/var\/www\/html\/nextcloud\/lib\/private\/Files\/Storage\/Local.php#140","userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:59.0) Gecko\/20100101 Firefox\/59.0","version":"13.0.1.1"}
{"reqId":"i2UPSwHkjJ08DdeciaHd","level":3,"time":"2018-04-15T11:39:18+00:00","remoteAddr":"192.168.0.25","user":"user@domain.com","app":"PHP","method":"GET","url":"\/index.php\/login\/challenge\/totp?redirect_url=\/index.php\/settings\/user\/security","message":"stat(): stat failed for \/mnt\/FreeNAS\/nextcloud\/data\/appdata_ocamqr445cu4 at \/var\/www\/html\/nextcloud\/lib\/private\/Files\/Storage\/Local.php#140","userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:59.0) Gecko\/20100101 Firefox\/59.0","version":"13.0.1.1"}
{"reqId":"i2UPSwHkjJ08DdeciaHd","level":3,"time":"2018-04-15T11:39:18+00:00","remoteAddr":"192.168.0.25","user":"user@domain.com","app":"PHP","method":"GET","url":"\/index.php\/login\/challenge\/totp?redirect_url=\/index.php\/settings\/user\/security","message":"touch(): Unable to create file \/mnt\/FreeNAS\/nextcloud\/data\/appdata_ocamqr445cu4\/js\/core\/merged-template-prepend.js because No such file or directory at \/var\/www\/html\/nextcloud\/lib\/private\/Files\/Storage\/Local.php#204","userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:59.0) Gecko\/20100101 Firefox\/59.0","version":"13.0.1.1"}
{"reqId":"i2UPSwHkjJ08DdeciaHd","level":3,"time":"2018-04-15T11:39:18+00:00","remoteAddr":"192.168.0.25","user":"user@domain.com","app":"PHP","method":"GET","url":"\/index.php\/login\/challenge\/totp?redirect_url=\/index.php\/settings\/user\/security","message":"touch(): Unable to create file \/mnt\/FreeNAS\/nextcloud\/data\/appdata_ocamqr445cu4\/js\/core\/merged-template-prepend.js.deps because No such file or directory at \/var\/www\/html\/nextcloud\/lib\/private\/Files\/Storage\/Local.php#204","userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:59.0) Gecko\/20100101 Firefox\/59.0","version":"13.0.1.1"}
{"reqId":"i2UPSwHkjJ08DdeciaHd","level":3,"time":"2018-04-15T11:39:18+00:00","remoteAddr":"192.168.0.25","user":"user@domain.com","app":"PHP","method":"GET","url":"\/index.php\/login\/challenge\/totp?redirect_url=\/index.php\/settings\/user\/security","message":"touch(): Unable to create file \/mnt\/FreeNAS\/nextcloud\/data\/appdata_ocamqr445cu4\/js\/core\/merged-template-prepend.js.gzip because No such file or directory at \/var\/www\/html\/nextcloud\/lib\/private\/Files\/Storage\/Local.php#204","userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:59.0) Gecko\/20100101 Firefox\/59.0","version":"13.0.1.1"}
{"reqId":"i2UPSwHkjJ08DdeciaHd","level":3,"time":"2018-04-15T11:39:18+00:00","remoteAddr":"192.168.0.25","user":"user@domain.com","app":"index","method":"GET","url":"\/index.php\/login\/challenge\/totp?redirect_url=\/index.php\/settings\/user\/security","message":"Exception: {\"Exception\":\"OCP\\\\Files\\\\NotFoundException\",\"Message\":\"\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/Files\\\/Node\\\/Node.php(217): OC\\\\Files\\\\Node\\\\Node->getFileInfo()\\n#1 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/Files\\\/Node\\\/Node.php(117): OC\\\\Files\\\\Node\\\\Node->getPermissions()\\n#2 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/Files\\\/Node\\\/File.php(62): OC\\\\Files\\\\Node\\\\Node->checkPermissions(2)\\n#3 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/Files\\\/SimpleFS\\\/SimpleFile.php(104): OC\\\\Files\\\\Node\\\\File->putContent('(function($) {\\\\n...')\\n#4 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/Template\\\/JSCombiner.php(194): OC\\\\Files\\\\SimpleFS\\\\SimpleFile->putContent('(function($) {\\\\n...')\\n#5 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/Template\\\/JSCombiner.php(103): OC\\\\Template\\\\JSCombiner->cache('\\\/var\\\/www\\\/html\\\/n...', 'merged-template...', Object(OC\\\\Files\\\\SimpleFS\\\\SimpleFolder))\\n#6 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/Template\\\/JSResourceLocator.php(113): OC\\\\Template\\\\JSCombiner->process('\\\/var\\\/www\\\/html\\\/n...', 'core\\\/js\\\/merged-...', 'core')\\n#7 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/Template\\\/JSResourceLocator.php(69): OC\\\\Template\\\\JSResourceLocator->cacheAndAppendCombineJsonIfExist('\\\/var\\\/www\\\/html\\\/n...', 'core\\\/js\\\/merged-...')\\n#8 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/Template\\\/ResourceLocator.php(78): OC\\\\Template\\\\JSResourceLocator->doFind('js\\\/merged-templ...')\\n#9 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/TemplateLayout.php(306): OC\\\\Template\\\\ResourceLocator->find(Array)\\n#10 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/TemplateLayout.php(146): OC\\\\TemplateLayout::findJavascriptFiles(Array)\\n#11 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/legacy\\\/template.php(207): OC\\\\TemplateLayout->__construct('guest', 'core')\\n#12 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/public\\\/AppFramework\\\/Http\\\/TemplateResponse.php(157): OC_Template->fetchPage()\\n#13 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(114): OCP\\\\AppFramework\\\\Http\\\\TemplateResponse->render()\\n#14 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/AppFramework\\\/App.php(115): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch(Object(OC\\\\Core\\\\Controller\\\\TwoFactorChallengeController), 'showChallenge')\\n#15 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main('OC\\\\\\\\Core\\\\\\\\Control...', 'showChallenge', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#16 [internal function]: OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke(Array)\\n#17 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/Route\\\/Router.php(297): call_user_func(Object(OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler), Array)\\n#18 \\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/base.php(998): OC\\\\Route\\\\Router->match('\\\/login\\\/challeng...')\\n#19 \\\/var\\\/www\\\/html\\\/nextcloud\\\/index.php(37): OC::handleRequest()\\n#20 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/nextcloud\\\/lib\\\/private\\\/Files\\\/Node\\\/Node.php\",\"Line\":97}","userAgent":"Mozilla\/5.0 (X11; Ubuntu; Linux x86_64; rv:59.0) Gecko\/20100101 Firefox\/59.0","version":"13.0.1.1"}
'passwordsalt' => 'mdjTN7M+bJB+3tebS6j6i9gCJ3mwUx',
'secret' => '2NTj21gf4a3DQbWOMbLzmXX0DD6zKi6eAcI+9H+p67jX+JSF',
0 => 'nextcloud.domain.net',
'datadirectory' => '/mnt/FreeNAS/nextcloud/data',
'overwrite.cli.url' => 'https://nextcloud.domain.net',
'version' => '13.0.1.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => 'foo',
'mail_from_address' => 'nextcould',
'mail_smtpmode' => 'php',
'mail_domain' => 'domain.net',
'instanceid' => 'ocamqr445cu4',
[Sun Apr 15 00:07:19.191852 2018] [mpm_prefork:notice] [pid 633] AH00163: Apache/2.4.25 (Debian) OpenSSL/1.0.2l configured -- resuming normal operations
[Sun Apr 15 00:07:19.191925 2018] [core:notice] [pid 633] AH00094: Command line: '/usr/sbin/apache2'
[Sun Apr 15 12:27:30.976285 2018] [mpm_prefork:notice] [pid 633] AH00169: caught SIGTERM, shutting down
[Sun Apr 15 12:27:31.334463 2018] [mpm_prefork:notice] [pid 29541] AH00163: Apache/2.4.25 (Debian) OpenSSL/1.0.2l configured -- resuming normal operations
[Sun Apr 15 12:27:31.334623 2018] [core:notice] [pid 29541] AH00094: Command line: '/usr/sbin/apache2'
[Sun Apr 15 12:37:11.147562 2018] [mpm_prefork:notice] [pid 29541] AH00169: caught SIGTERM, shutting down
[Sun Apr 15 12:37:11.507444 2018] [mpm_prefork:notice] [pid 29606] AH00163: Apache/2.4.25 (Debian) OpenSSL/1.0.2l configured -- resuming normal operations
[Sun Apr 15 12:37:11.507609 2018] [core:notice] [pid 29606] AH00094: Command line: '/usr/sbin/apache2'
[Sun Apr 15 18:30:44.056131 2018] [core:notice] [pid 29606] AH00052: child pid 30941 exit signal Segmentation fault (11)
[Sun Apr 15 18:30:44.102546 2018] [mpm_prefork:notice] [pid 29606] AH00169: caught SIGTERM, shutting down
[Sun Apr 15 18:31:07.999484 2018] [mpm_prefork:notice] [pid 590] AH00163: Apache/2.4.25 (Debian) OpenSSL/1.0.2l configured -- resuming normal operations
[Sun Apr 15 18:31:08.001109 2018] [core:notice] [pid 590] AH00094: Command line: '/usr/sbin/apache2'
