Nextcloud version (eg, 18.0.2): 19.04
Operating system and version (eg, Ubuntu 20.04): CentOS (shared hoster uberspace.de)
PHP version (eg, 7.1):
The issue you are facing: If I edit markdown documents via the embedded web texteditor, it loses regularly the sync:
file could not be loaded. Please check your internet connection (retry)
This occurs right after a few minutes and I guess a tip faster if you are on a edit. This error occurs on different internet connections.
- Open Files app on your cloud webinterface
- Click a textfile to edit
- Start writing to the opened file and wait till the above poppup message appears
- Click rety and note, that nothing will reload. So reload the whole page
Info files_versions Expire: /todo-neu.md.v1604050096
2020-10-31T14:46:45+0100
Info files_versions Expire: /todo-neu.md.v1604146048
Info files_versions Expire: /todo-neu.md.v1604146364
Info files_versions Expire: /todo-neu.md.v1604146489
Info files_versions Expire: /todo-neu.md.v1604146882
Info files_versions Mark to expire /todo-neu.md next version should be 1603975689 or smaller. (prevTimestamp: 1604062089; step: 86400
2020-10-31T14:46:44+0100
Info files_versions Mark to expire /todo-neu.md next version should be 1604143669 or smaller. (prevTimestamp: 1604147269; step: 3600
PASTE HERE
PASTE HERE
