temporary 2fa code generated by 2fa admin tools not accepted when client uses it
    • 32.0.9
    • Ubuntu 22.04.5
    • 2.4.67
    • none
    • 8.3
    • yes
    • months ago, never tried the functionality before then
    • snap
    • no
temporary 2fa code generated by 2fa admin tools not accepted when client uses it in production, works fine in fresh install.
  1. Create domain controller and nextcloud ubuntu snap in same network
  2. Create user in Active Directory and link NextCloud to it, install totp addin and admin tools for 2fa
  3. Client generates own 2fa in google authenticator and logs in normally using qr initial setup
  4. generate temporary totp in admin tools for 2fa, client uses it no problem
cannot add for security reasons. please suggest places to look.
If the problem is related to the Web interface, open your browser inspector Console and Network tabs while refreshing (reloading) and reproducing the problem. Provide any relevant output/errors here that appear. n/a
n/a
n/a
n/a - security reasons
Hey @esolomon, welcome to the Nextcloud community and thanks for supporting Nextcloud snap :handshake:
Sorry to hear you are having issues with your Nextcloud snap installation. If you’ve come this far, you’re on the right track! There is a good chance someone in the community has had a similar issue and knows how to resolve it.
In order to help you we’ll need some Information to get an Idea of your setup, so post the output of the following command allowing us to look at your redacted configuration file:
sudo nextcloud.occ config:list
Nextcloud logs are very verbose, thus your logs will certainly help resolve your issue. access your logs by following how to manage Nextcloud snap logs or you could run the debugging script and post the result here or paste the result of the following command:
sudo tail -n 20 /var/snap/nextcloud/current/logs/nextcloud.log
Below are some links to how-to’s answering frequently asked questions and may help you help yourself;
