$Temp folders are visible in document structure on web
Nextcloud 29 on Ubuntu Server 24.04 LTS with Apache web server
This installation is about 2 weeks old.
In the web interface I often get a folder named $Temp showing up, usually inside a top folder, after doing some work on files in a child folder.
temp
(Screenshot of a blue folder named $Temp)
When I reinstalled a couple of weeks ago, I noticed a lot of these folders after uploading content to NC (drag and drop, because I like the wait).
I can easily delete $Temp folders, but they will eventually show up again after a while.
So how do I get rid of them permanently?
Thanks!
Are these folders located on External Storage or is the underlying Nextcloud data directory accessed by anything outside of Nextcloud?
Nextcloud is installed on a single machine. Files are synced between that and my work pc which is set up as a dual boot Fedora Workstation / Windows 11.
I also sync to my android phone (nearly forgot that).
So in essence, you can say that some files exist in a few different instances.
I have had quite a few installations over the past two years, but I don’t remember seeing this before.
