Hello there, I am facing error with mariadb. I tried my best possible to resolving it. But can’t from my end. Now i decided to reinstall nextcloud instance at last. So i have my ssh with my local file manager accessed. So can i take my files out from it? Which folder does it contain my data?
That’s challenging to answer without more details about your installation, such as that asked for in the support template.
However, you may find the Maintenance chapter of the the Admin Manual useful. It covers backups, restoration, server migrations, etc.
There are at least three places that contain data you may care about:
- your database (within MariaDB/etc)
- your config (
config/
within the Nc installation folder) - your files (located with the
datadirectory
specified in yourconfig/config.php
